This incredible set is coming out on or about Sept 22. Msrp is $1699.00.
4:3= 36"
16:9= 33"
Spec sheet:
http://www.sonystyle.com/intershopro...xs955specs.pdf
Current Sony Style (store) deal:
KD-36XS955- 1699.00 msrp
Free stand
Free delivery (stand is going to be delivered first)
12 months no payments no interest - store only
Free remote (programmable) - store only
$119 5 year warranty
This set does lack Firewire, PNP, and 2nd generation resolution, however this IS comparable to the 960 in all other areas.
Spec sheet of XBR960:
http://www.sonystyle.com/intershopro...R960_specs.pdf
Features:
The KD-36XS955 also features an ATSC Integrated Tuner and is Digital Cable Ready with a CableCARD Slot. ClearEdge VM (Wideband Velocity Modulation Scanning), and an HDMI/HDCP Interface separate this television from others. You can even view your family photos onscreen and listen to MP3 audio with the built-in Enhanced Memory Stick® Media slot.
Full HDTV (built-in ATSC tuner for over-the-air HD reception)
Hi-Scan 1080i Display accepts the full 1080 interlaced scanning lines (1080i) or 720 progressive scan (720p) from an external HDTV receiver or a compatible high definition digital satellite receiver. It also accepts 480 progressive (480p) scanning lines from compatible DVD video sources.
SuperFine Pitch CRT provides better image detail with high definition sources. The Aperture Grill was improved by making the vertical slits a finer pitch that increases the number of slits by up to 65%(16 x 9 base). Also improved were the High Precision Deflection Yoke, Fine Focus Electron Gun and the inclusion of higher intensity Luminescent Phosphors. The result is a more detailed image for both moving and still images, higher resolution picture quality, and better edge detail.
HD Detailer Wideband Video Amp provides greater detail on finer images, delivering the best possible image from high bandwidth sources.
ClearEdge VM (Wideband Velocity Modulation Scanning) allows you to select levels to create better separation between an object and its background for clearer edges, greater picture depth and improved overall picture quality.
ATSC Integrated Tuner allows the reception of local, off-air digital broadcasts providing the viewing of free, true high-definition network programming without the addition of a set top box or a monthly fee.
Digital Cable Ready with CableCARD Slot A set of hardware specifications that are defined to include a removable security module, which separates the cable operator's proprietary conditional access system from the retail digital cable device, to enable portability of the host to other cable networks.
HDMI Interface (High-Definition Multimedia Interface) - HDMI is the first industry-supported, uncompressed, all-digital audio/video interface. HDMI provides an interface between any audio/video source, such as a set-top box, DVD player, and A/V receiver and an audio and/or video monitor, such as a digital television (DTV).
HDCP Interface (High-bandwidth Digital Content Protection) was developed to protect digital entertainment content across a DVI interface. It also serves as the security system for HDMI.
CineMotion Reverse 3-2 Pulldown improves the display of video programs originally shot on 24 frames per second film preserving the integrity of the original film frames for more fluid motion and more fine detail.
Memory Stick® Media* Enhanced Playback (JPEG,MPEG1,MP3)
4:3= 36"
16:9= 33"
Spec sheet:
Free stand
Features:
