AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Huntsville, AL - HDTV
Huntsville, AL - HDTV - Page 15
post #421 of 2849
I noticed Boston Legal started in HD, then went SD (well, upconverted 720p). That's a good sign.
Bad thing was, their signal was terrible, it used to be 100%, now it's about 25%. Hope they turn it back up.
post #422 of 2849
Originally Posted by alwilli View Post
I have had a calibration and several touchups (although I will skip this year since I got my Spyder2 Pro colorimeter to play around with). Calibrations can add up. I had Gregg Loewen from Lion AV do mine. I can not recommend having a calibration done by Gregg enough. It was worth it for me but your mileage may vary. If you have a CRT RPTV I would highly advise it...not so much if you have a fixed pixel digital with DVE or Avia.
Alvin
What kind of TV do you have? An now since you have a colormeter, are you going to try an do some calibrating on the side?
post #423 of 2849
I can not speak for the future, but for now I have no plans to calibrate on the side. If I did I would have to invest in more accurate (and more expensive) equipment. And most importantly, I would need the experience and knowledge of color science to feel comfortable charging people. I bought the colorimeter as a cheap alternative to having my units recalibrated over and over as I change components. See this thread for info:
http://www.avsforum.com/avs-vb/showthread.php?t=572098
I have a Toshiba 42H82 CRT RPTV, an Infocus 4800 DLP front projector, and a Samsung HLP-5063W DLP. HT is my hobby and is very expensive. And I have low budget equipment and a modest setup! I don't plan on buying anything else anytime soon (5 years). I have other things more important now financially.
post #424 of 2849
Did anyone here watch "NCIS" last night? My audio was terrible last night.
post #425 of 2849
Ditto.
post #426 of 2849
WAAY now has the side bars. They must be getting ready to go HD if not already. It is 8:30am. 31.1 channel. At last
post #427 of 2849
Yes...WAAY will have "Lost" and "Invasion" in HD tonight...if they don't mess it up.
Wolfie
post #428 of 2849
Wolfie have you got that from somone at WAAY. They had what appeared to be the capability last night for there HD shows but didn't "flip the switch".....
post #429 of 2849
Their first show last night was in HD, I believe it was Life With Jim??? It appears they were still testing since at one point you could see when they switched from 720p to 480i and back again.
post #430 of 2849
I never saw it go to 480i, just from true 720p HD to 720p Upconvert. Just analyzed their signal remotely and here's what I saw:
31.1 is listed as WAAY-HD
31.2 doesn't have a name
Their PIDs look correct, so there shouldn't be a problem with viewers receivers.
31.1 is of course 1280x720p @ 15Mbps, DD2.0 @ 192kbs
31.2 is 720x480i @ 4Mbps, DD2.0 @ 192kbs
Let's give them the rest of the week or so to work out the bugs.
post #431 of 2849
Voicemail from Chief Engineer at WAAY saying the are up with HD and experiencing some minor hickups but are good to go..... Awesome. (To bad it is a week past when my beloved Redskins played there only MNF game)
post #432 of 2849
Taz, how did "Life with Jim" look??
post #433 of 2849
Whats the power level like. A couple of weeks ago i was getting WAAY very good and was pleased sinc ei have had trouble getting a signal in the past. recently it has been very hard to get a signal. Have they upped the power back to what it was or maybe i need to rescan the channel.
post #434 of 2849
I didn't check out "Life with Jim". I lucked out even flipping to WAAY when I did (after "House"). Like I said, it was only HD for a few seconds so I couldn't really get a good look at it. Since Lost is on tonight, that'll be a good measuring stick. At 15Mbps, it should be enough for 720p, though I don't know what kind of encoder they have.
btw, just remotely checked signal levels, they look a lot better now than they did last night.
post #435 of 2849
thanks taz
post #436 of 2849
Life with Jim looked incredible last night. It was broadcast in hd for the first 20 or 30 minutes before it switched back. Power level was at 90% ota in south Huntsville.
post #437 of 2849
Anyone know whether WAAYHD (assuming it really close to being a reality) will be offered on comcast?
post #438 of 2849
I hope Comcast picks it up ASAP. I'm watching Lost in OTA HD right now and it looks beautiful, but the sound is coming from my tv speakers since my 5.1 is hooked up through the Comcast HDDVR. I can't complain about the picture, but I hate waiting for Comcast
post #439 of 2849
Hallelujah!! "Lost" in HD.
post #440 of 2849
call comcast and ask them when they are going to have channel 31 in hd. we all need to do this.
post #441 of 2849
I will call Comcast first thing in the morning, man it sure does look good right now!! (OTA also)
My brother has Knology, and he just has a blank screen in his HD section for WAAY.
Thanks so much guys at WAAY for jumping on board!
post #442 of 2849
That is what I am getting too.
Actually, I'm having trouble getting good consistant HD signals from Knology for about the past week. Some of the HD channels show up as 480i instead of 1080i, and ESPN and Fox show up as 1080i instead of 720p.
post #443 of 2849
Sweet! I can't believe HD on ABC is finally here!
On a good night I can pick up a weak signal out of Nashville, but it usually had so many dropouts, it isn't worth watching. So now, hopefully, I won't have to worry with it anymore.
post #444 of 2849
Really nice watching abc hd. now we will be able to see all the sports in hd. we now have almost all of the stations. we now need espn2 hd on comcast, i have been calling, hope you are too.
post #445 of 2849
Saw the ABC in HD like the others here. I would like to congradulate WAAY on a job.....done.
post #446 of 2849
Does anyone know what channel on Comcast is the ABC HD?
post #447 of 2849
They dont have abc on comcast yet. call and let them know you are waiting for it.
post #448 of 2849
Did ya notice that "Lost" was superb PQ, but "Invasion" was lacking. I guess the higher rated shows get the best PQ.
Wolfie
post #449 of 2849
While I'm as glad as the rest of you that WAAY-31 has joined the HD arena, it's all for not if the reception is broken. JUST this morning I'm experiencing heavy dropouts on all DTV broadcasts with PBS being the only exception --> they're a STEADY 90%
I have not made any adjustments to my antenna(s) but this odd phenomenon reaks of atmospheric effects with the heavy cloud cover... although WZDX hasn't been stable in a while. How's your reception?
post #450 of 2849
WAAY's reception was all over the place last night, I finally switched to another channel. All other channels were fine.
