AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Miami / Ft. Lauderdale, FL - HDTV
Miami / Ft. Lauderdale, FL - HDTV - Page 5
post #121 of 6828
Scott --
Forgive me for mentioning the obvious, but have you considered removing the antenna from the rafters and placing it in the original position?
I can think of no reason why you would receive WSVN and not WPLG. What signal meter readings do you get?
You might also try a channel re-scan.
Bill Brenner
[This message has been edited by wjbjr (edited 06-18-2001).]
post #122 of 6828
Originally posted by wjbjr:
Scott --
Thanks for the response, Bill. I should have mentioned trying that in my previous post. I did, in fact place the antenna in the original location, with no luck, which is why i was so confused. That's why I believed WPLG either reduced power, or shut down completly. I receive channel 10 analog clear, but nothin on 9, LOL. Signal strength for 8-1 is about 73, and 22-3 is 64.
Wow. While writing this, i did a rescan... i now get 9-1 with a strength of 83. LOL, how simple!! i figured just tuning to the station would work... DUH!
I really appreciate the time you and everybody else has spent answering.
Scott
post #123 of 6828
It's 10:45 and WPLG has completely forgotten to throw the switch for NYPD Blue.
post #124 of 6828
WHDT-DT - Channel 59 - MIG
Anticipated Debut - before July 31, 2001
Work remaining - Build & Install Antenna
Phone: (561) 471-9200
Email: info@whdt.net
WFLX-DT - Channel 28 - FOX
September 1, 2001 per TitanTV
Rumored intention to broadcast 480p - a welcome improvement over WSVN's 480i.
Phone: (561) 845-2929
Email: rsanluis@raycommedia.com
Email: bfigurella@raycommedia.com
WTVJ-DT - Channel 31 - NBC
October 5, 2001 per TitanTV (Same date as FCC Extension)
Phone: (305) 379-6666
Email: WTVJ Feedback Form
WBZL-DT - Channel 19 - WB39
December 1, 2001 per TitanTV
July, 2001 per HD Pictures
Phone: (954) 925-3939
Email: wbzl@tribune.com
post #125 of 6828
Its been a long time since i been here.How many digtal channels does south Florida have? Well at least in Miami?
Last time i was only to view Rick Sanchez on 8.1 and WPLG
9.1 or 10.1...Dont remember.I think its time to get back in action and do my part...how will you rated them? from 1-10?
10 being the best! thanks guy...
post #126 of 6828
Nilson,
WSVN-FOX Channel 8
WPLG-ABC Channel 9
WPBT-PBS Channel 18
WFOR-CBS Channel 22
post #127 of 6828
Has anyone else, especially in southern Miami-Dade, experienced a major decline in the WFOR signal?
Mine was at a very satisfactory 60s to 70s until Tuesday, when it inexplicably dropped to the unwatchable 30s, where it remains. The other DT channels are still at 100.
The antenna does not appear to have moved -- there has been no wind -- but I will check it if no one else reports a similar decline.
Bill Brenner
post #128 of 6828
FWIW, the Harris DTV transmitter for WPEC-DT, which should be on the air sometime in the first quarter of 2002, is scheduled to be delivered to our west Lantana transmitter site this afternoon. This is the first in a very long list of gear that will need to be installed and tested over the coming months to get WPEC-DT on the air. You can see what it looks like here: www.broadcast.harris.com/transmission/tv/platinumcd.html .
HiDefDave
STOP HDCP!
post #129 of 6828
Well, the truck broke down in Jacksonville. I sure hope this is not an omen!
HiDefDave
STOP HDCP!
post #130 of 6828
Rumor....rumor....rumor
gives me a Palm beach county tumor
another casuality of war
just like W...for
yes.. we are committed to 2002 or three
the waiting hurts like something from a bee
i think it is WPEC
post #131 of 6828
george,
My CBS readings are down. From 64-70 to only 58! Yes, i can s(p)mell low power. Retuning your antenna should help. Got it back up to 64 but in different position!
post #132 of 6828
Yes, my CBS signal is down to half what I had.
I loose 4-1 almost every night, and have to unplug my HD5 and reset it ???
Don't know why yet.
Signal goes to 40-45 at night, but 55-65 in the day ??????
You would think it would be the other way around???
I think the DirecTV list may have something to do with the loosing of the 4-1.
Even at 45, and after a reset, I get CBS.
But, I don't loose HBO in the rain, (with my dish), so there is a silver lining !
post #133 of 6828
Hi, for last 3 days i can only receive wpbt and sometime WFOR on the panasonic51 but even less on the dish6000, but i lost WSVN and WPLG totally, can any one tell me what would cause that problem no signal on WSVN and WPLG. i used to get about 80s for those channel and WFOR in th 60s. i can get the WPBT in between 85-90. my location is in the corner of SW18 street and Lion rd in boca raton. thanks for your help.
[This message has been edited by Chan (edited 06-24-2001).]
post #134 of 6828
I used to get 65 with my Terk attic antenna, now only around 50.
Then I used to get 93 with my amplified indoor ant., so, I reconnected it and the best is 27.
This is bad data, because I can not establish the original results. Since the signal changed and I changed antenna's I don't have a baseline for my data.
The good news is that I now have a new diplexor, which shows minimal lose through it. Which it should, because it is not a spitter, but a low / high pass filter.
The weather does not help either. I wonder if this is part of the problem.
post #135 of 6828
post #136 of 6828
I am setting up my attic antenna.
Hardrock, can you post where you believe the transmitting antenna's will be for each of the above stations ??
Thanks in advance.
post #137 of 6828
Transmitter: 26° 43' 37" N 80° 4' 48" W
Transmitter: 26° 34' 37" N 80° 14' 32" W
Transmitter: 25° 58' 7" N 80° 13' 20" W
(Same location as WFOR-DT)
post #138 of 6828
Thoose stations are NOT on the air!!!!
post #139 of 6828
Hi everybody,
Are we all still experiencing audio problems when tuning
in to channel 2.1 or is it just me?.
I usually have to turn the RCA box on and off two or three
times before finally getting the audio to come on.
The video comes up right away all the time.
Thanks for your replies
Helier
post #140 of 6828
Rapid stuttering and/or complete loss of the audio on WPBT is still a problem for me (I'm using an RCA DTC100). Sometimes going to the SAP icon in the INFO menu and clicking twice brings the audio back, but not always. Switching channels back and forth also works sometimes; when that doesn't work I dial in 18.2 or 18.1 on the remote and that does the trick.
post #141 of 6828
hardrock,
Would it be too much trouble to put the 2 station locations on a map ?
I am looking for bearing lines for antenna pointing.
Since the bottom 2 are @ WFOR, which is where I will point the best signal, I want to be able to get the top 2 when they start to transmit.
Thanx
post #142 of 6828
Coordinates: 26° 43' 37" N 80° 4' 48" W
Transmitter: 1601 Forum Place, West Palm Beach
Coordinates: 26° 34' 37" N 80° 14' 32" W
Transmitter
You can also use Microsoft's TerraServer
post #143 of 6828
post #144 of 6828
post #145 of 6828
Only in south FL...maps! Can someone give me directions to WTVJ parking lot. I want to hold a protest!
post #146 of 6828
How to get to the new NBC 6 Studios in Miramar
WTVJ
15000 SW 27th Street
Miramar, FL 33027
(954) NBC-6000
post #147 of 6828
FYI, as of Saturday, still no evidence of antena work being done on Gunther's roof (WHDT-DT.)
HiDefDave
STOP HDCP!
post #148 of 6828
Dave,
WHDT has continually misrepresented the status of their debut. With all of the money they've spent, I'm beginning to think that they'll fold before they ever get their product to market.
post #149 of 6828
Hardrock;
Thanks for the maps.
G.
PS Any rumors on when NBC will do testing ?
post #150 of 6828
George,
WTVJ will probably request another extension beyond their current deadline of Friday, October 5, 2001. Their petition to change Channels from 30 to 31 has been pending with the FCC since July 13, 2000. I'm sure they plan to milk that for all it's worth.
Petitions to Change DTV Channels
