Dave;
Thanks, but I suppose the amp did nothing, or did DirecTV tell you.
If you set up install on the receiver, and get a avg. transponder signal value, then add the amp. what is the value ????
Did it go down, stay the same, or improve.
Yes, I know that the amp is for cable loss, but an amp is an amp.
And, it needs a certain signal level at the input, and will produce an output signal. If the signal is within the ??? input parameters, it will amplifiy to give you a better signal. But if it is too large, it will do nothing, or can over load and attenuate.
So, was it a did nothing or what ???
Because when cloudy, the signal goes down, and just maybe the amp will bring it up to good levels.
And , yes, if the signal goes to almost zero in rain, Nothing will help.
