Originally Posted by mx6bfast
I'm moving from Memphis, TN to Coral Springs in 2 weeks. Is this the correct thread I should follow or the West Palm Beach one? Coming in to say hi.
Ok next question, we will be in zip code 33065. I use Comcast internet currently and they said they don't service the range of the house we are going to rent. Are my other options only Advanced Cable or ATT? If so how are the speeds? I will be working from home temporarily so I need to have a reliable internet connection.
I use OTA and record as much as possible from that instead of the D* feeds. Doing a antennaweb search looks like we are mostly around 20 - 23 30 miles from the different towers. Good times for me!
Welcome to South Florida. You're in the right place for Coral Springs. In CS, your options for internet are AT&T and Advanced Cable. I had a business in Coral Springs for a while and had Advanced for both TV and Internet. They were OK... there were periodic outages as I used to have with Comcast in my home. Also, speeds would vary depending on how many people were using the shared bandwidth, but that wasn't a major problem that we had. We also offered free WiFi to our customers using Advanced so it worked well.
At home I use AT&T and their 6 Mb package for internet. It's worked very reliably and I get good throughput. Both are good, so I suspect you might want to consider what other options you might need, via TV and Phone and make your decision that way.
