I just called buydig, described the problem and checked for the option of exchange. Got a quick NO. They claimed they don't exchange TV, period. All problem should go to manufactor. When I asked that some internet users did have the experience of replacing a defective DLP set with BD, I was told that truth wasn't be told by "those users" because BD never did that.
Well, I guess that's how internet shopping works, saved me a couple of hundred bucks but no service afterwards. Will wait for the tech guy.
If the tech guy does something to the light engine, either fix or replace, that shouldn't have some extra impact on other aspects of the TV, right?
Originally Posted by Traveler62
I had a noise that I first thought was the fan, but ended up being the color wheel. The way I found out that it was the color wheel was I would change between different input sources to the TV and the pitch of the noise would change briefly. If it is a fan, that should be an easy change. If it is the color wheel, you might want to have them send another TV out and take that one back. You could have the Light Engine changed, but you are in the period that you can send it back. I had a cosmetic issue with my TV from Buydig and they were great at sending out another no charge.
Any help would be appreciated.
