You should use a UHF antenna connected without any coupler or spliters between the antenna and your HDTV receiver. I and others have had problems with splitters and surge protectors dropping the signal strength of the digital signal before it reached the receiver. Point the UHF antenna towards the Sandia Crest (to open V side towards the crest) and use the auto scan on your receiver if equipped. Hopefully if will work for you. You should always be getting the PBS signal (channel 35 I believe) and the KOB signal (not sure #). They are both always on. Good Luck.
post #331 of 7411
4/25/02 at 7:00am
