Hi there I have a question for you tweakfreaks out there.
I have a Barco Graphics 808s with a fried green tube. The tubes in this one are regular 07MFP02 tubes.
I also have a Barco RetroGraphics 808s with fresh tubes. Just a slight notion of wear on the green tubes.
It's the L-shaped RetroBlock with HD-8 lenses on. With lots of extra functions such as green convergence, contrast modulation, geometry axis adjustments and so on.
The problem is those tubes are Panasonic MEC tubes. They are called
P16LXW33RJA (red)
P16LNQ57HKA (green)
P16LXW33BMB (blue)
I was wondering if someone in here has ever made an attempt to put these tubes into a regular Barco Graphics 808s and what electronic components would need to be swapped from the RetroBlock to the regular 808s to make it happen?
I am considering doing this since I got both projectors really cheap and was hoping I could do this conversion and get me a nice and fresh regular Barco Graphics 808s in the end.
What do you think?
Can it be done?
P16LXW33RJA (red)
P16LNQ57HKA (green)
P16LXW33BMB (blue)
What do you think?
Can it be done?
