A couple of weeks ago, I originally posted my experience with my first 50VS810 that suffered from horrible black levels and green bleed. Since then I have received and returned another unit for similar but different problems. The replacement solved the black level issues completely, but it still suffered from minor green bleed, mis-convergence by about 1 pixel (white text on a black background such as in the menu had a 1 pixel wide green stripe on the left side and 1 pixel wide magenta stripe on the right of the letters, see attached picture), the entire image was rotated about 1 degree counterclockwise, and there were what looked like smudges behind the protective screen that were visible on an all gray screen.
Yesterday, I loaded up the second 810 into my SUV again for another trip back to CC and was pretty concerned about getting a third unit that would have similar problems. CC was accommodating in that they allowed me to take the new tv out of the box and plug it into the wall so that I could look at the menu for mis-convergence and also look at a screen of "snow" to look for green bleed. Although their wasn't perfect convergence, it was nowhere near a 1 pixel shift. I have looked extensively for green bleed now that I have the tv home and I haven't noticed any.
I can finally say that I am a very happy owner of an 810 and am quite pleased with the product I ended up with. This tv has to be one of the best looking tv's outside of plasmas that I have seen. The black levels are great and watching football and others show in HD is truly an eye-opening experience. In fact, I think the picture is clearer than if you were at the game yourself since you aren't relying on 20-20 vision. I should also mention that the Z-Line Designs tv stand (Model ZLN 23541S) and matching component stand from CC are a perfect fit for this tv. Although the tv is wider than the stand (the side speakers hang over the edge on both sides), I like the look. The stand has shiny black glass with a black and silver metal frame which match the silver and piano black case of the 810 perfectly. I'll try to post a picture of that as well if I get a chance. Thanks to everyone here at this forum, it's been quite comforting to hear that others were experiencing similar problems to mine and that they were resolved by exchanging for another tv.
MY sincere apologies if I threw anyone off!
