AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › How long can a DVI cable be?
post #1 of 20
I've found a 15' DVI cable and a 20' Monster cable (at about 4 times the price) but I haven't found a DVI cable any longer than that. Does anyone know of a longer cable or does anyone know if I can get a female to female adapter and put two 15' cables together? Is there a technical reason why that wouldn't be a good idea?
post #2 of 20
Forget that Monster priced cable you found.
Already been down this road. Look up and click on the sponsor link for RAM Connectivity Solutions. The other place to look is http://www.bluejeanscable.com/
Basically, both of those sites have high quality cables and for a 30' DVI cable you are still only looking at 100 bucks or so. I run a 30' DVI cable from blue jeans and it is perfect. RAM will go up to a 50' dvi cable, but I barely can deal with the delay in a 30' run while my player syncs up with my pj. I fear a 50' run might be a little long, but should still work.
Both have no questions return policy, so just buy what length you need and return it if it doesn't work for you.
later.
post #3 of 20
i have a 10meter DVI cable from ram electronics that works great from my HTPC to my projector.. they are expensive though, i think around $200 cdn.
Craig
post #4 of 20
www.monoprices.com the only place you need to go. I have an extension I will sell you.
post #5 of 20
Thanks, I'll look into those sites.
post #6 of 20
I just ordered a NXG "high performance" 20' DVI from buyextras.com for $43. They have a 30' for $69.95. Looks nice, we will see how it performs.
post #7 of 20
Does that mean the video is not in sync with the audio? If so, how serious is it?
Has anyone else noticed this?
post #8 of 20
bump.
I would like to know the answer to shunx's question too.
post #9 of 20
While experiences vary, the "standard" for DVI cables without getting into sparklies issues is 7.5m. Again, may people report no issues with some longer cables, but it is hit and miss. It also depends on what resolution you will be using.
I have a 10m Lindy DVI cable between my HTPC and Sanyo PLC-XP30, and I have sparklies at 1024x768 but not 800x600. I compensated for the problem with signal amplification (Gefen DVI distribution amplifier).
By the way, I have no issues with audio/video sync at 10m.
post #10 of 20
I had occasional sparklies with my 10 meter Lindy cable.
I got fed up after a while and got a 10 meter from better cables. Still had sparklies. Ended up getting the 6 meter exchanged at bettercables, no more sparklies! Unfortunately, I ended up rearranging my equipment around the room to do so...
I think that 720p is the most bandwidth intensive HD resolution. I never had sparklies on games that ran 800X600.
Lots of people have success with the 10 meter DVI, I wasn't one of them.
I think that staying at/under the 7.5 meters is almost guaranteed success.
post #11 of 20
jeffleonard.
What resolution were you using? 800x600? 1024x768?
post #12 of 20
Radeon 9500 -> 10m Lindy SLD DVI-D cable -> Panny 500 ... Works perfectly with 1280x720.
post #13 of 20
Originally posted by egress123
jeffleonard.
I run 1280 X 720 @ 60Hz via my HTPC with a ATI Radeon 9700 Pro.
post #14 of 20
Here's a weird question. I have an infocus 4805 so I got their M1-DVI 10m cable. However it's not long enough (story of my life) and I would like to use a DVI extension cable. I saw some that were dual link but the Infocus cable is single link. The question is would a dual link extension cable work on a single link dvi cable? The single link cable should "fit" in the female end of the dvi dual link extension cable but I'm not sure.
post #15 of 20
I purchased a 30' dvi cable from Ram Electronics and have a beautiful picture with no problems of any kind. Sim2 projector with a Bravo Dvd player and Directv HD.....awesome
post #16 of 20
The reason why I was interested in people's resolution is because I am struggling whether to purchase X2 or 4805.
I definitely want to go with DVI cable and it has to be at least 30' long. If 30' DVI cable can support 1024x768 resolution without any problems, I wanna go for 4805. However, if this is going to be a problem, i would rather go with X2.
can someone comment on this?
post #17 of 20
Egress,
I wouldn't base your projector purchase on the DVI cable. You can buy equipment to amplify the signal if you get stuck. I know that spending extra $ isn't really that great of an option, but it is an option.
Get the projector that you really want, and you can work out any connectivity (<- is that a real word?) issues if you have one.
By the way, if spending extra cash on little upgrades isn't in your nature, building a theater may not be a good hobby for you. Because it will turn into your hobby!
post #18 of 20
jeffleonard, Why not? to me, paying 500-600 more for 4805 is worth to get 4x wheel DLP, DVI, and brighter projector is worth it. However, if I have to pay 300 dollars for the amplifier if 30' DVI is not good enough, then it's going to be 800 to 900 more. then it's not worth going for 4805 over X2.
I'm sure that's the same reason why you went thru all the hassle to return your 10meter cable to 6 meter cable and rearranged your Home theater configuration, instead just buying one amplifier. Budget, man. that's one important factor on everything.
post #19 of 20
I started another thread that I will ask a moderator to merge with this one.
Seems the concensus is 7.5m -- but for what resolution? Many cable boxes feed 1920x1080 (1080i). Because of the increase bandwidth, would you expect 7.5m to shrink?
post #20 of 20
bump
This thread is locked
