Well, now I did it. 52725, manufactured in '04. Replaced the bulb about a year ago. Recently I've been getting some weird video noise (bands of static), so I decided to tear my baby apart and have a look. Other than being totally filthy inside, everything looked good. Believe it or not I couldn't find a single swollen cap, let alone any that were leaking. So I went about my business and reassembled everything. Demated all my connectors and cleaned all the contacts before reconnecting.
Finally got it all together, and now I have the BGLOD. Must have missed a connection in there somewhere, though I can't imagine how. Stranger things have happened.
Guess I get to tear it apart again.
**UPDATE**
Well, took it all apart. Only thing I found was that one of my ribbon cables wasn't completely seated. It also looked like I crimped it on one side (must've pulled on it when fighting to get everything back together). Reassembled, and there was the BGLOD again. Thought I was going to have to hunt down a new ribbon cable. Let it sit for a few hours, came home, and it was still blinking. A quick reset, and whaddaya know...everything seems to work again.
Still have a fairly poor picture with random video noise, so all my work was for naught. Now I just gotta figure out whats really wrong.
**UPDATE PART DEUX**
BGLOD is back. Turned off the TV to put everything back together. Had to remove the filter cover, which triggered that switch (had a flashing orange light then). Got it all back together and the damned green light is there mocking me.
**UPDATE TRES**
Cannot get this damned thing to fire up. Wondering if that damaged ribbon cable may have an intermittent short or something. I'd like to replace it, just to check. Unfortunately, I can't figure out what the part number is (let alone a place to order it).
Can anyone help? It's the white one at the middle bottom of the pcb.
**UPDATE**
After sitting all night with the BGLOD, another restart this morning and the set fired up. Been running strong for half an hour now. Fingers crossed.
