You said if you unplug it and replug it you get the green blinking light and it will eventually go off. This is good and desired. I assume that it will stay off and not try to power on immediately by itself. It only has a problem when you try to power it on.
Are you using the remote to power on or the power button? It sounds like it tries to power on by it self when I read your problem description. If the TV tries to power on by itself make sure the power on button is not broken or permanently trying to power the TV on (depressed). If you are powering on with the remote try the power button on the TV.
It seems that the most frequent symptom is the BGLOD all the time. The set will not initialize or boot. If yours does that and it seems that does not, and it will not power on that is a different symptom. If you get a flashing light there are codes that can be read from the resulting blinking LEDs.
The front panel LEDs provide an indication of the sets operation, and the possible cause of a malfunction. There are three front panel LEDs, “Power”, “Status” and “Lamp”. Which LED is lit, the color, and whether it is blinking or
steady indicate the current status, or a possible malfunction.
This was posted by another member.
http://www.avsforum.com/avs-vb/attac...7&d=1147791778
there is also an operational check...
Error Code Operational Check
Note: The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
Error codes..
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Jack
- The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
- The flashing then pauses for approximately 1/2 second.
- The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times. - The Error Code is repeated a total of 5 times
Error codes..
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
Jack
