ISCAN HD+ for CIH setting questions:
1. Can you feed 1080p/60fps or 1080p/24fps to Iscan HD+? I am a bit confused. I thought it would only accept up to 1080i input. If it accepts 1080p input, can I do the zooming and panning as described below in question 3?
2. In case the answer for the question 1 is no, if you feed 1080i from blu-ray discs with 1080p, will there be any loss in picture quality? My projector is hc5500 which can accept 1080p/24fps.
3. Does HD+ have flexibility as DVDO Edge or DVDO VP30/50 in terms of zooming and panning? What I am planning is to vertically zoom the image in letterbox (to eliminate the black bars) and then shift up the image a little bit so that the subtitles in the bottom black bar can be shown.
Please anyone clarify the points. Thank you.
Although the BD-P2500 does the squeeze for 4x3 content, it doesn't provide the needed vertical zoom feature.
