Originally Posted by Uncivil
The setup was working successfully with the amp and no breakup until I rotated the antenna enough to bring in 9-1. I didn't immediately notice the break up. I also added a splitter in the line. Is it possible the splitter is causing the problem? I am running quad shield from the antenna to the preamp. Then I am using existing RG6 in the wall that was there for cable before I ran new line for DirecTV.
It is a cheap splitter but its all that I had.
Should I start with removing the preamp and trying i without it?
Then should I replace the splitter?
I don't have a whole lot of options other than leaving it in the attic. I don't have the ability to mount an antenna that size outside and its out of my price range to have someone do it.
Thanks for all the help.
Get a CM4228 then, they are little easier to mount since they aren't wide antennas.
You can try replacing things but I don't think it will help. The only channel that is used for the large part of the antenna is ABC-HD. All the other channels are UHF using the yagi part on the front.
You could also try another location in the attic.
but today its gone.
