Originally Posted by Clint S.
Does anyone know of a site that lists stations' power output? I seem to remember someone on this thread saying WAFB had only 9kw. But here it says 46kw (ERP)...(5.5kw at the top, but 45kw at the bottom. ??)
You are reading the wrong channel info...the 46KW ERP was for their UHF 46 pre-transition channel...the current VHF 9 is the current one at 5.57KW.
Also look at the HAAT. The UHF 46 was lower on a different tower.
WBRZ it says only 30kw! If that ERP data is correct it says WGMB is 1000kw which I guess explains why that's only 1 of 2 I can receive. But the other I can receive is LPB which is only 20kw. Apparently that's due to them being UHF, where WBRZ, and AFB are VHF. But WVLA is UHF and according to that FCC site, 1000kw! So it doesn't make any sense why I can't receive it. There's two areas for "ERP" on each page so maybe I'm not looking at the right ones. But both say "digital".
Again, check the channel listed..and tower location...also the numbers in the FILE No. shows the date of the application, etc (EXAMPLE: BMPCDT-20080619AJK shows 06/19/2008 as the date) In most cases the later date is the correct one...(Evidently WAFB has not gotten their license to cover...or the FCC web page is not updated..which happens sometimes!)
Thanks for the info.
