AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Baton Rouge, LA - HDTV
Baton Rouge, LA - HDTV - Page 93
post #2761 of 2942
Originally Posted by dennispap View Post
I had 2 timers for fox44 for sunday night @ 6pm and 6:30pm and both didnt record due to No signal. Fox 44 is still off of the air for me now, but i am getting nbc33@ 95% and all other ota stations so i dont think it is my antenna.
Anyone else getting fox44 OTA?
WGMB is off the air due to extensive transmission line repair requiring cleaning of soot from the entire 1800 foot run of transmission line to prevent further damage.
post #2762 of 2942
Thanks for the info.
post #2763 of 2942
How's the repair coming? When is the estimate WGMB will be back up? Charter needs 44.2 to get WBRL here in Assumption parish.
post #2764 of 2942
The last report I had says that the crews have worked their way through about 500 feet of line from the top down an indications are that the entire run will need to be cleaned and upwards of 75 connector springs (bullets) will need to be replaced. Parts have arrived on site and completion will be no earlier than this weekend as of now.
post #2765 of 2942
Thanks for the update!
post #2766 of 2942
Assuming the weather holds the tower crews should complete repairs today and WGMB should return to full power on-air operation sometime this evening.
post #2767 of 2942
Thanks for keeping us updated on things. I'm itching to return my FOX timers back to OTA
post #2768 of 2942
Still off air here. Anyone else picking up ota?
post #2769 of 2942
I currently live in Denham and have a very nice HD setup with DishNetwork...I will however be moving into an area of Denham over the next month that offers UVerse...I just want to know if anyone has it or has compared it to Dish, and would it be worth it to change....Prices are about the same, so picture quality would be the worry...Only running the one HDTV on it...
post #2770 of 2942
I've heard the picture quality is horrible on HD and you can only stream 2 HD streams at once.
Even with my only one HDTV, I record 3 HD streams at one time on my DishNetwork DVR more than 2-3 days out of the week.
If you can handle only the two streams, I'd try it out and see how it works and run them side by side and compare which one takes a hike.
post #2771 of 2942
44 still off air here
post #2772 of 2942
Cleaning of the transmission line was completed yesterday.
Analyzer showed anomalies at three locations 700ft,1400ft,1450ft.
Inspection showed water accumulating in the inner conductor insulators.
Cracked flanges due to hurricane force winds need to be repaired.
The line is being dried out with nitrogen today.
post #2773 of 2942
As always... the detailed updates are appreciated.
post #2774 of 2942
Yes, thanks fox44ce, just checking to make sure it wasnt my setup.
post #2775 of 2942
Fox44 came back on the air this evening but at reduced power.
Normally i get them at 99-100% but they were only coming in in the low 70's.
At least that is a good start
post #2776 of 2942
Both are around 90 here. I know WVLA used to be 100% since they fixed it but now it's back down to 90%.
post #2777 of 2942
When is This TV returning to 33.2?
post #2778 of 2942
Probably when they get the antenna totally fixed. They are broadcasting fox44 on 33.2 for now while they fix the problems.
post #2779 of 2942
Ill have to check when i get back in town but i know friday morning wvla was in the low 80's and wgmb was in the low 70's. Hopefully when they get all of the problems fixed they will go back to full power as those 2 were rock solid in hammond.
post #2780 of 2942
Right now wgmb fox44 is@79% and nbc33 is@84%.
All my other br stations are normal. Hopefully 33 and 44 go back to their full power.
post #2781 of 2942
They re back as of a few days ago.
post #2782 of 2942
Everyone better check their timers as tonights episode doesnt show as a "new" episode, as the listing shows the girls, which was supposed to be broadcast last night. If you have them set for NEW it wont record.
This is from my Dishnetwork/tribune info.
post #2783 of 2942
Seems like you should set it to ALL anyways... there aren't reruns Thanks for the heads up. I checked mine for the girls in the house and it was set to ALL.
post #2784 of 2942
I used to have it to all but fox44 used to show american idol redux (some kind of recap show from years past) on the weekends and it was recording those also.
post #2785 of 2942
I'm not picking on WVLA -- our friendly poster Fox44CE has had enough recent drama swapping out a third of a mile of transmission line -- but I had to chuckle at today's news story about a cable "transporter" taking out 33's feed this morning. Perhaps Cox could have used a "patch cable" to plug in an alternate feed from an OTA "TV set"? Just sayin...
http://www.businessreport.com/archives/daily-report/2010/mar/08/1506/
Cox subscribers who switched on their TVs this morning to catch the Today show were surprised to find the local NBC affiliate was off the air. For nearly two hours, between 7 a.m. and 9 a.m., WVLA NBC-33 and its sister station, WGMB FOX-44, were off the cable airwaves due to a technical issue on Cox's end. Ann Ruble, a Cox spokeswoman, says a transporterthe electronic device that carries a station's signal from its transmitter to Cox'smalfunctioned, causing the cable company to lose the WVLA/WGMB signal. The transporter has been replaced and upgraded to include a backup component, which Ruble says is designed to prevent such outages in the future.
post #2786 of 2942
Anyone notice on the WBRZ news that the live shots from the LSU baseball stadium were in HD? They had another live shot from Livingston parish in SD, night and day difference.
post #2787 of 2942
No, but i noticed that channel 19 ota thru my dish receiver still doesnt have any audio
Not that i watch it anyway, but it is sort of hard to potentially watch any station that doesnt have audio
post #2788 of 2942
Late last night i picked up quite a few of the Beaumont/Lake Charles/
Lafayette/Houston channels.
3-1 katc
7-1,7-2,7-3 kplc
15.1,15.2 kadn
18.1,18.2,18.3 lpb
20.1 ktxh Houston (was showing Law and Order in HD)
29.1,29.2 kvhp
34.1,34.2,34.3,34.4,34.5, kitu Beaumont,Tx 5 different religious channels
post #2789 of 2942
No, but i noticed that channel 19 OTA thru my dish receiver still doesn't have any audio
Not that i watch it anyway, but it is sort of hard to potentially watch any station that doesn't have audio
We have been working with DirectTV and Echostar on issue that they have been having with interruptions of audio on their up links and OTA set-top tuners.
Our research has shown that both have problems with decoding audio when the stream has a large number of null packets.
Unfortunately due to the method we are using to multiplex the WBRL-HD and KZUP-SD streams on the digital STL, both have a significant amount of null packets OTA.
This does not appear to effect the majority of TV 8VSB tuners but does effect the set-tops of both DirectTV and Dish Network.
To correct this issue we would need to decode and re-encode both stations at the transmitter site.
The equipment to accomplish this is extremely expensive.
post #2790 of 2942
What's weird is 19 had audio on it for the first few weeks after the digital flash cut. 21 had no audio from the start.
Seems like the they need to figure out what is messing up their OTA tuner and update instead of the other way around with you guys trying to patch it.
