Ken H
AVS HDTV Moderator
{If you're going to use their CableCARD, what difference does their hardware make?
Also, I would check about the cost of a CableCARD vs. a CV supplied STB. Usually they are about the same rental cost per month, but a CableCARD doesn't have the interactive on screen display or PPV.}
I meant that I am going to use cablecards for 2 TVs but I still have one where I can't use a cable card. For that do I have choice for any CV receivers? I checked rental fee for cablecard: it is about $1.29/month.
& you are right it doesn't have interactive feature, that is exactly what I want because of my kids.
Thanks for input.
AVS HDTV Moderator
Thanks for input.
