AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › Fable and 480p output
Fable and 480p output - Page 3
post #61 of 69
Originally posted by fezz135
I dont know some of these methods arent workin for me for some reason.
I have a Sony XBR 60". I havnt got the latest XBOX live update, but i updated it not too long ago. I have the option to choose if my TV supports 480p or not.
Help?
You need the update that lets you toggle the dashboard between 480i and 480p. This is not the same as the setting in the menu.
post #62 of 69
That's messed up. To make Fable work properly, you require a broadband connection, even though it's not an online title? Whew. People bitch about computer patching.
post #63 of 69
No. The quickest way to update the Dashboard is to have a connection to Xbox Live. Many games have also included the updates (and I thought demo discs, but could be wrong). Fable--because it's not an online game--did not.
Fable won't play in 480p automatically on a very small subset of HDTVs. For everyone else--myself in this bucket--the game is plug-n-play in 480p.
--T.
post #64 of 69
--T.
Well, as far as "a very small subset of HDTVs" goes, I work for a software development company and we have 5 different HDTV capable monitors, a dozen office HDTVs of different brands, and then including my co-workers' home equipment a few dozen more HDTVs. On top of this we have access to a few X2VGAs as well as X2VGA+... I can assure you that every single one of these with a non-patched ***NEW XBOX*** dashboard the game will not display *UNLESS* the TV can support or otherwise resample the bizarre resolution that Fable is actually in.
There are also problems with other titles, some do not go away with the dashboard upgrade (panzer dragoon is one of them).
Sift around on the net and you will find many, many people who have issues with the oddities of both new XBOXes as well as the goofy resolution that Fable comes in. If you get access to a television that will tell you the "actual resolution" regardless of what it might be forcing it to, you will be able to confirm this.
Some older XBOXes have no need for the patch for games to work in 480p, that is true enough, but your generalization or guesstimates couldn't be less correct.
Google it if you doubt it, this is becoming a well known problem with newer batches of xboxes.
post #65 of 69
I'm not sure what you're point is. I never said anything about unpatched xboxs. Some other poster made the errant claim that you have to have a broadband connection to play Fable (in order to download the "fix"). I countered with "no, the patch is widely available through other mediums."
I believe that the necessary workaround (forcing 480p mode) is only necessary on a small subset of HDTVs. Not that unpatched xboxs have no problems--I have no idea and really have no reason to doubt your claim. I find it irrelevant to the discussion though, since a patch is available.
We are discussing Fable and Fable only. If you want to add other games to the discussion, feel free, but I specifically was talking about the Fable issue--don't extrapolate my comments to include "all HD games."
My question to you: after patching, how many of the TVs did not automatically play in 480p? How many required the workaround? This was the issue I was addressing...
--T.
post #66 of 69
tristanc,
i believe that what fell tried to say about your comment "on a very small subset of HDTVs" was that it implied that fable+480p worked on some HDTVs and not on others, as in... the HDTVs have the problem. This is not the case. The problem seems to be happening to some XBoxes and not others, independent of the HDTV.
I myself have this problem on my new xbox (v1.6) and NOT on my old one (v1.1). After searching through some forums, it appear to be a problem with newer xboxes only.
joselucas
post #67 of 69
Originally posted by joselucas
tristanc,
joselucas
Ah, thanks joselucas--that makes sense. I thought we had ruled out the issue being with new Xbox vs. old Xbox earlier in this thread but perhaps not.
Does the patch fix the problem on the newer xboxs?
--T.
post #68 of 69
I, too, had the prob with Fable until I read that above. I loaded up Burnout 3 and I went to the xbox live setting where it installed the latest patch allowing the dashboard toggle.
hth,
John
post #69 of 69
Yes, patching the Xbox lets you change the dashboard to 480p, which forces Fable to work in 480p correctly. Doing this causes another problem for me though. Sometimes I can't stop the intro movie by pressing buttons on the controller. This only happens sometimes when using the 480p-dashboard workaround.
Lucas
  Back to Forum: Home Theater Gaming
This thread is locked
