Here's a brief summary of the OTA channels available in the Twin Cities, arranged by analog channel number (numbers less than 1000kw or directional are not full-powered unless otherwise noted):
KTCA (TPT2) - digital 34 - PBS HD 24x7 feed. 340kw directional.
WCCO (CBS) - digital 32 - fully HD compatible. 1000kw.
KSTP (ABC) - digital 50 - fully HD compatible. 1000kw.
KMSP (Fox) - digital 26 - fully HD compatible. 691kw (full power) directional.
KARE (NBC) -digital 35 - fully HD compatible. 1000kw.
KTCI (TPT17) - digital 16 - 5 PBS multicast. 50kw (full power).
KMWB (WB) - digital 22 - HD compatible. 20kw directional.
WFTC (UPN) - digital 21 - no HD. 1000kw (full powered) directional.
KPXM (Pax) - digital 40 - no HD. 1000kw (full powered) directional.
KSTC (Ind) - digital 44 - multicast analog 45 and HDNet. 205kw.
Local website devoted to Minneapolis/St.Paul HD programming/stations:
www.hdtvtwincities.com
is picking up UHF over the air. If you get 23 and 29 with decent reception with not a ton of snow, you shouldn't have any issues getting the digital signals.
