Originally Posted by obeone
Hello rrrrrrobert,
Thanks for keeping tabs on this. The video web link you posted is the very same one I used to construct the antenna my kid has been testing the last 2 weeks.
So far the results have been disappointing. He's tried locating this antenna in no less than 16 locations around the apartment, in both vertical & horizontal orientations, and can only get 3 or 4 stations at best. These stations typically include PBS (17), FOX, WB , PAX and occasionally a choppy CBS. Of all the stations, the PAX broadcast from all the way in St. Cloud is the strongest, while he's have never captured a signal from ABC or NBC just 6 miles away. Go figure.
Yesterday, he tried propping the antenna in his north facing windows (the only windows available) at various angles (and with the window open) with no real improvement over anything else he's tried.
At this point I'm not sure what to do. Should we try some type of amplified antenna? I'm not sure. Some web sites recommend them, others do not. Maybe if we can find some old rabbit ears like you had rrrrrrobert.
Any other ideas would be appreciated.
-obeone
Hello rrrrrrobert,
-obeone
Perhaps this has been already suggested,but the quality of the tuner makes a HUGE difference in the reception of ATSC channels.The newer (5th generation?) models have much improved performance. In an apartment,multipath would be your biggest enemy. New tuners reject or actually reuse reflected(multipath) signals. A new tuner might save you a bunch of experimenting with antennas?
