| The lower contrast is needed so it doesnt trip the protect 1-2. You have to hit store then enter for it to store a setting. |
Right, I understand that. But: 1) how can I store something in a VIDEO signal if I can't display the VIDEO signal? I can't edit the CONTRAST on a non-active signal, can I? and 2) what exactly gets stored when you hit STORE? **ONLY** the thing you're currently displaying? (e.g. if I hit PIC FUNC and adjust CONTRAST, then hit STORE, does it store the CONTRAST value but not the BRIGHT value?)
And even if the CONTRAST was too high on the VIDEO, wouldn't the AKB TEST mode defeat that?
| I would say the pots have been turned if it wont run on no input if set to the test position in video or the video default was overwritten at any one time. |
Oh, LOVELY. :(
| There is a 'back door' you can try but first think what rgb setting you had when it fired up (signal entry line) and if the computer was fully booted and running the signal. If you can power it up there it will tell us alot. |
Are you saying what RGB setting it had when **my laptop** (NOT the computer in the XG) was fully booted up? Yes, the computer was booted up and displaying a desktop -- if I didn't have a signal from the laptop, then the XG shuts down. Yes, I can get the values when it fires up. What exactly do you want from the signal entry line? The frequencies for RGB are 15.74 kHz and 59.94 Hz, - & - sync. What else do you need?
| On the XG RGB input is 1, video is input 2, and s-video 3. |
??? You don't mean the signal input 1 2 and 3, do you? On mine, signal 01 is NTSC3.58, 02 is NTSC4.43, 03 is PAL, 04 is SECAM, 05 is VESA1024 (RGB), 05 is DVD (component), 06 is PC (RGB, the signal I created for my laptop), 51 is NTSC 51, 52 is NTSC 52, 53 is RGB 53.
| Confirm the composite video is working with a TV first. You may not have it selected on the DVD player. |
Certainly possible, and in fact at least once I had it plugged into the VIDEO IN instead of VIDEO OUT on the combo DVD/VCR. (D'oh!! :)) Unfortunately I don't have a TV that accepts composite in!! But, hmmm. I DO have some VCRs that accept video in... :) So yes. Now I'm certain there's a good composite signal going into the VIDEO input.
Are you **SURE** I can't calibrate it using RGB? :( Especially given the comments on p. 10-24 saying "If the adjusting signal is different, " etc? But I suppose if things are as hosed as it appears they may be, then even if it was OK to calibrate on RGB, I've still got other problems.
Gary
