Ohhh... you know what.. that probably explains why I see these R5000HD Interfaces popup in front of me on my desktop unexpectedly when a recording starts sometimes (even though I have the option set for hiding it in "iconic" mode in the taskbar.
Another unusual behavior is when flipping through the different tabs on the interface, it has this weird focus issue where I'll lose focus of the interface and it will hide behind another window (if there is one).
I tried contacting their support recently about this with respective screenshots, but, never received a reply back. I'm not sure if I should attempt to try again; or, thats their way of saying I dont get support anymore from them (even though I've spend more than 2 grand and refered over 8 grand <-edit worth of customers) in the last couple of years.
Originally Posted by boiler11
I know there's a separate process for each instance. When you run the r5000hd.exe, it spawns more processes for each instance. I believe the way in which they spawn the process is the reason why it's difficult to kill, not that it's "tied" to the driver. But then again, I didn't write the code ...
It was really hung, sage was correct. I neglected to mention, but when I logged into the server, I had a windows dialog indicating that the process had terminated improperly, or something along those lines. I don't remember exactly how they word it. However, when that happened with the older versions of the app, the process would really go away. With 3.1c, it does not.
Note that I'm NOT using the new 3.1c options to load at startup and auto recovery, they are disabled. I'm pretty sure the statup option loads at user login, not at boot. I don't usually log onto my server, so load at login doesn't work.
I could probably get the proxy working with 3.1c to avoid the crashes, but there's no real benefit. My wife was tired of me messing with it, so I'm back to 3.0c ...
Sean
Sean
