Matthew [redacted] <[redacted]>
________________________________________
Windows 7 Media Center
11 messages
Matthew [redacted] <[redacted]> Wed, Oct 20, 2010 at 6:26 PM
To:
r5000support@nextcomwireless.com
Hi, I purchased the R-5000 VIP 211 premod last year.
I'm loving it so far, but now I'm thinking of reprovisioning my Quad-Core PC to become a home theater PC running Windows 7 x64.
My question is this: Do I need to purchase a special version of this software, or can I use the standard drivers to work with Windows Media Center edition?
Thanks so much for your time,
-Matt [redacted]
r5000support Thu, Oct 21, 2010 at 10:42 AM
To: Matthew [redacted] <[redacted]>
Hi,
I'm not sure if you're asking if WMC functionality is supported or if you can use the R5000-HD with a Win 7 x64 Media Center edition PC. The answer to WMC support is no, it is not supported, but to install and use the R5000 on a Media Center edition PC is the same as any other. Just download and run the installer for the appropriate package, in your case the Vista/Win7 x64 bundle.
Win 7 does supply as standard, software decoders for H.264 video so you can play any ViP211 HD recordings without adding anything special -just launch them with WMP or WMC. However, the R5000 USB driver and DVR app has to be loaded from our installation package. Thanks,
JD
[Quoted text hidden]
Matthew [redacted] <[redacted]> Thu, Oct 21, 2010 at 11:46 AM
To: r5000support
ohh, I was grossly mistaken then, I was under the impression that you supported it as a tuner in Windows Media Center (a'la sage tv) and was wondering if, like sageTV, there was an upcharge for that software. I could have sworn when I bought this, I read something about it being supported in Media Center, and the underlying software would also record raw streams so the recordings weren't locked down to the encrypted media center format.
back to the drawing board, i suppose. I was planning to use WMC with a WMC Extender in another room. I'm not sure if SageTV offers something similar...will have to look into that.
At any rate, thanks for getting back to me, I do appreciate it.
-matt
Matthew [redacted] <[redacted]> Thu, Oct 21, 2010 at 11:50 AM
To: r5000support
so I'm seeing instructions on how to set up the R5000 as a tuner in MCE here:
http://www.nextcomwireless.com/R5000...ual_setup1.htm
So did you mean to say that you only support XP MCE and not Win7 Media Center?
r5000support Thu, Oct 21, 2010 at 12:01 PM
Where is that link on our website?
Matthew [redacted] <[redacted]> Thu, Oct 21, 2010 at 12:02 PM
To: r5000support
http://www.nextcomwireless.com/R5000...ual_setup1.htmhttp://www.nextcomwireless.com/R5000...nual_setup.htm
If it works with XP MCE only, then I can work with that, but I'd prefer win7 mce.
Matthew [redacted] <[redacted]> Thu, Oct 21, 2010 at 12:06 PM
To: r5000support
I'm not entirely sure where it's linked from the main page, but here's the page from which the previous two were linked:
http://www.nextcomwireless.com/R5000...mce_manual.htm
Introduction
The MCE version of the R5000-HD DVR supports the Windows® Media Center Edition (XP and Vista 32). In addition to the special version of the DVR app, a set of drivers is installed providing a fully integrated Media Center tuner. The new software impersonates an NTSC tuner/capture device whereby the R5000-HD device is installed as a connection to the imaginary S-VHS or composite input. Now, full advantage can be taken of the integrated guide and scheduling features of Media Center while still producing the same high-quality HD (and SD) streams.
the emphasized portion is what I'm after.
r5000support Thu, Oct 21, 2010 at 12:09 PM
Yeah, but where did you get that link from?? Where can you get to that from our site?
Matthew [redacted] <[redacted]> Thu, Oct 21, 2010 at 12:12 PM
To: r5000support
http://lmgtfy.com/?q=R5000+Media+Center
Matthew [redacted] <[redacted]> Thu, Oct 21, 2010 at 12:13 PM
To: r5000support
(BTW I didn't mean that in a snarky sort of way, but yes, I did just search for "R5000 Media Center" in google and 3 of the 4 top results are the links I referred to.
r5000support Thu, Oct 21, 2010 at 12:21 PM
Hi,
These are obviously old, outdated links. Anything current will be referenced on our site, for example WMC support. I can't speak to what was experimented with 2 or 3 years ago with XP but trust me there is no support for it now. All you would have to do is look at what software is referenced from our support page.
