The output formats available for VideoRedo Plus are:
MPEG Program Stream *.mpg *.mpeg
Elementary Streams *.mpv *.mpa
DVD Stream *.vob
None of those are *.ts and If you load a *.ts file without doing any thing to it and try to save it it asks you: There is no cuts defined, Do you wish to re-mux the entire input file?
And like I said I compared the two files input and output and there is a difrence, you may not notice the diffrence on a CRT monitor but with HD LCD monitor it's a little bit of diff.
DVD Stream *.vob
