AVS › AVS Forum › Video Components › Home Theater Computers › HTPC - Mac Chat › TV will see the mac, but the mac will not see the tv
post #1 of 5
toshiba 57h93 built in tuner
i have a 57h93 toshiba hdtv w/built it tuner. it will see the mac but i can't get the mac to see the tv.
under the play side it shows 1 connection but 0 on the record side.
is there a setting i'm missing?
thank you
post #2 of 5
daylight,
Do you have CableCard? There is a bug with CableCard on Scientific Atlanta systems that will prevent recording. Of course, you can't record DTV/HDTV cable channels with a PC or Mac anyway, because they don't support 5C encryption.
post #3 of 5
Not using cable for HD, taking ATSC off air with the built in tuner. the 57h93 does not have the cable card, the h94 does.
I have the h93.
post #4 of 5
i can't get it to work! need to invest in a dvr.
post #5 of 5
For people to help you, I think you need to supply a bit more information -- like the steps you used to setup recording on the Mac.
  Back to Forum: HTPC - Mac Chat
This thread is locked
