Here is a summary of what is available in the greater Houston area for HDTV:
Over-the-Air
The main antenna farm is located in the southern part of town (near Sugarland/Missouri City), about 14 miles Southwest of downtown. I personally use an attic-mounted Channel Master 4-bay bowtie antenna connected to a Channel Master 7777 pre-amp and have no problems with reception (note: you do lose some sensitivity by using an attic mount) from deep inside the loop.
Update: With the help of Bob Chase, I found that my original set-up was overdriving my HD Tivo. As a result, I am now only using the CM4221 in my attic.
Station Offerings: (last update 7/9/06)
Note (2): Since an ATSC digital channel is 19.2 Mbps, the stations which simulcast/multicast in 1080i will more than likely have worse signal quality than those that are multicasting with 720p due to lower compression ratios.
Information about addresses, license contacts, etc., can be found here, or via the FCC.
Here is an old thread that has some contact information (telephone numbers), and some good suggestions on how to contact people at the stations themselves when you want to report an issue.
CATV Options
Antenna Recommendations
The place to start when contemplating adding an OTA antenna is www.antennaweb.org. After you plug in your address, the site will tell you both what class of antenna (e.g., red, violet, blue) you need and what direction you should aim it to get which signals. Since Houston has a joint "antenna farm" on the south side of town, this makes aiming a breeze for virtually all stations (e.g., the majority of antenna are on bearings between 202 and 205 degrees from my houst just outside of downtown).
Antennae that are popular:
If you have any corrections, additions or questions - please let me know!
Later,
Bill
Over-the-Air
- Call Sign (Network, Network HD Standard) - Analog Channel, Digital channel
Sub-channel details - KPRC (NBC, 1080i) - Analog: 2, Digital: 35
Contact: Edgar Zavala (AVS UserID: kprcdt) - dtv@kprc.com
2-1 - HDTV (1080i)
2-2 - NBC WeatherPlus(tm) (480i) <-- A weather forecast with audio overlay from main channel, and some video
2-3 - Weather radar (480i)
2-4 - SD Simulcast - KUHT (PBS, 1080i) - Analog: 8, Digital: 9 (VHF, 8.7kW)
8-1 - HDTV (1080i)
8-2 - SDTV simulcast (480i) - KHOU (CBS, 1080i) - Analog: 11, Digital: 31
11-1 - HDTV (1080i)
11-2 - Weather radar (480i) - KTRK (ABC O&O, 720p) - Analog: 13, Digital: 32
Contact: Chuck Primrose (AVS UserID: CAPHouston) - Charles.A.Primrose@abc.com
13-1 - HDTV (720p)
13-2 - News/Special Interest (480i)
13-3 - Weather radar (480i) (the lightning tracker is cool!) - KETH (TBN, ???) - Analog: 14, Digital: 24
14-1 - SDTV (480i) simulcast of Trinity Broadcasting from analog channel
14-2 - SDTV (480i) The Church Channel
14-3 - SDTV (480i) JCTV
14-4 - SDTV (480i) TBN Enlace USA - KTXH (Independent) - Analog: 20, Digital: 19
20-1 - HDTV (1080i) - KLTJ (Daystar, ???) - Analog: 22, Digital: 23 (Galveston) DT License: Construction Permit
- KRIV (FOX O&O, 720p) - Analog: 26, Digital: 27
26-1 - HDTV (720p) - KHCW ("The CW" O&O, 1080i) - Analog: 39, Digital: 38
Contact: Bob Chase (AVS UserID: bobchase) - bchase@tribune.com
39-1 - HDTV (1080i)
39-2 - SDTV (480i) The Tube Music Network - KXLN (Univision O&O, ???) - Analog: 45, Digital: 46
45-1 - SDTV (480i) - KTMD (Telemundo O&O, ???) - Analog: 47, Digital: 48
47-2 - EDTV (480p) - KPXB (PAX, ???) - Analog: 49, Digital: 5 (Low VHF, 9.5kW)
49-1 - ??? (???)
49-2 - ??? (???)
49-3 - ??? (???)
49-4 - ??? (???) - KNWS (Independent, n/a) - Analog: 51, Digital: 52
- KTBU (Independent, n/a) - Analog: 55, Digital: 42
55-1 - ???? (????) - KAZH (Azteca, ???) - Analog: 57, Digital: 41
57-1 - SDTV (480i) - KZJL (Independent, n/a) - Analog: 61, Digital: 44
61-1 - SDTV (480i) - KFTH (Telefutura, ??) - Analog: 67, Digital: 36
67-1 - SDTV (480i)(???)
CATV Options
- The Houston Time Warner Cable thread is here
- No other threads identified - if any Phonoscope, et al., subscribers start a thread, please let me know so that I can update the list
- 4-bay and 8-bay "bowtie" - these UHF-only designs seem to provide great performance in a relatively compact footprint and are also relatively inexpensive (e.g., the Channel Master 4221/3021 can be had from AVS sponsor Solid Signal for under $40 shipped). They also seem to work reasonably well with "high VHF" (e.g., KUHT) signals, as well.
- Silver Sensor - This design is about the best simple antenna one will find. It is small and very sensitive, though highly directional. When it has been coupled with a high quality pre-amp, it is about as good of an indoor antenna as one will find. Unfortunately, this antenna (sold originally by Zenith) has been discontinued, so eBay or Sears (on closeout) are your best bets for finding one. iTech (a manufacturer of HD tuner cards for PCs) bundles a Silver Sensor with its AccessDTV product (or at least did when this author owned one). Other manufacturers seem to be using the Silver Sensor design, so there may be versions available under alternate names (cf.).
- Square Shooter - This antenna is relatively expensive (~$100+), but is effective. Its performance has been compared to a Silver Sensor with an amplifier, and it is one of the few antenna to generally get postive aesthetic comments.
- Terk - the Bose of antenna design. However, Terk antennae are generally available locally, whereas other manufacturers' products are special-order only. One model, the HDTVi, is reported to be similar in design to the Silver Sensor, but with the addition of VHF elements. It is also reported to be competitively priced with the Silver Sensor.
- In progress - last updated: 5/11/05
Later,
Bill
