Originally Posted by Da Rafsta
I'm in the Southeastern part of town, Fuqua/45S/Beltway S. In that vicinity. Until now, all channels have come in with no problems. I use an outdoor antenna that I literally have outdoors on a pole hanging about 25-30ft off the ground, moreso the latter. I should have no problems and haven't until recently....channel 11 or KHOU has started freezing, cutting off, total signal loss. This is soooo unacceptable given that the Texans are shown on said channel. I need a fix.
I was wondering if an amplifier is needed or if it would help any?
I have a similar setup at my home, and a couple of years ago, I noticed a lowering of signal strength, and most stations that I was getting with no problem, all of a sudden started dropping out. It turned out that one of my cable joints in my outside run had gotten water into the connection and had corroded the inside. Once I ran a new cable and made sure my connections were weatherproof, I was good to go.
By any chance, did your reception issues start after a recent rain storm?
) It's the digital remastered version by CBS with the Enterprise CGed.....Twilight Zone is on after ST!!!
