Hi all,
I am currently putting together a home theater in the basement. I have a TiVo upstairs, which I use a modulator (the cheapest I could find - http://www.smarthome.com/7715a.html ) to put its signal on channel 91. Currently, its signal upstairs (which has to travel through a whole bunch of splitters) is definitely noisy.
My question is - if I have a more direct run to my theater (sending the coax through only maybe 1 or 2 splitters), how good will the signal be? Given that this is going to go on a big screen (through an HTPC and dTV), I want to avoid signal degredation (on an already imperfect signal) as much as possible. I *could* run an S-video cable directly (I guess I'd convert the S-video into 2 composite cables because it's maybe a 50-100 ft run), but that would be a pain.
Will there be much degradation with a modulator compared to S-video cable? And does the modulator itself make a big difference?
Thanks in advance!
Mike
Thanks in advance!
Mike
