Originally posted by robrien
TByronT: Concerning the no audio on changing a channel with the Voom receiver. This known issue with the Voom box. Do you have the latest update: 6.20 or 7.x. This is not a problem with WVBT-DT.
Regards
Regards
How are you reading the firmware version from your Voom box? My numbers look nothing like the ones you suggest. I go to Options & Settings from the VOOM button screen; Choose System Settings; Choose 7. System Status; and I find Secure Firmware Version: V16.
Or, I can pick 8. Installer Menu; 1. Installation Wizard; and find a screen with: Software Version: 01.98.08, C0139, 00.06.20.
Anyway, even if it is a known Voom problem, but it only happens on two stations owned and managed by the same people, there can still be something wrong with the data streams they have created that clashes with the Voom problem.
Byron Thomas
I must admit that I'm lost here...are you saying that there is something besides the program material showing on your screen?
