Originally Posted by
obxdiver
HDTV is all UHF.
All you need is a simple UHF antenna.
Nope.
TV Broadcasting still uses VHF. In the US, abut 75% of full-power broadcasters are UHF, the rest are VHF with about 3 dozen on low VHF, channels 2-6.
You have to look at the channels in use in any particular area in order to determine what type of antenna is required. In Norfolk, for example, your ABC affiliate operates on VHF channel 13. Additionally, there are four other stations in the immediate area licensed to operate on VHF channels. You have to do your homework before recommending antennas.
The Leaf is a UHF design, but, in areas with strong enough signals, will work for VHF to some degree as it's too small electrically to be efficient on those longer wavelengths. YMMV.
