AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Detroit, MI - HDTV
Detroit, MI - HDTV - Page 369
post #11041 of 11539
I noticed this as well. Its too bad, I liked the way it was...
post #11042 of 11539
A lot of us did, too. But it wasn't sticking where it counted.
On the bright side, we get to skip the subchannel stuff. For now, at least.
post #11043 of 11539
Agreed, re: subs except I wouldn't mind getting a 'First Weather' sub that had radar + hourly forecasts... or any other weather based station amongst the Detroit/Windsor OTA's...
post #11044 of 11539
I've heard from different stations that the proliferation of smartphone and computer weather apps, plus the unlikeliness of cable carriage makes the money and effort to program one a nonstarter. As always, that could change. Heck, I've got a TV that grabs that from the internet and both my cable and DSS boxes have instant weather, too. My Windows Phone has the best radar app I've ever seen. And it's frighteningly fast to load and display. Zoom, move, motion.. all with fingertip access. You'd have to wait for a weather sub to cycle through to the view you wanted.
post #11045 of 11539
my face when ctrl+f, 1080p. zero results.
when are we gonna start getting 1080p?
post #11046 of 11539
You already have it from BD and select pay providers.
From linear TV channels? Probably never, because they will most likely evolve to higher resolutions (see the 4K topic in the HDTV Programming Forum: http://www.avsforum.com/avs-vb/showthread.php?t=1400304 ) as opposed to putting more infrastructure into existing standards.
post #11047 of 11539
PGA Golf today on NBC WDIV-DT. Dolby Digital is screwed up again; no feed for center & l/r surrounds.
post #11048 of 11539
I actually begged 'em to consider a lower virtual channel number so we'd be nested closer to the other network stations. Legal shot that down as there really wasn't an easy choice that wouldn't have drawn objections from an adjacent market. And a lot of cable systems have 'em all nested pretty close, anyway. So, CBS62 it is.
Definitely makes sense.
"CBS 6" would've been perfect, but I suspect the folks at WLNS in Lansing might not be too happy about that. (WLNS has a large viewership in Livingston County.)
The only VHF channel number not used for branding or PSIP in either Detroit, Windsor, Flint / Saginaw, Toledo, and Lansing is "3." However, "3" would be so radically different from "62" that using it would probably be a terrible idea!
So, in the final analysis, I'm cool with CBS 62.
post #11049 of 11539
What would have been wrong with 14? Co-owned WKBD uses it as their RF channel.
- Trip
post #11050 of 11539
Trip.. 14 is where they are on some cable systems. Plus, it's still at the high end (of cable net affiliate placement). So, 14 gets them nothing.
3 is out of the question since no cable system would put them there due to all of the converters that use 3 as an output. I don't know about Comcast, but every other cable system I've lived with used 3 as a billboard or some other useless access channel. Granted, nobody's ON 3, so ingress from the outside isn't an issue, but I'm guessing in-house interference was the primary reason 3 was never on the list. Moot now as they're sticking with 62.
post #11051 of 11539
Re: TV Ontario - TVO Digital Channel 32
TVO has been on the digital air since last September, when the Canadian digital transition occurred. They broadcast from the same tower as the CBC affiliate CBET, located in McGregor, ON. Here is a coverage map from our friend Trip at RabbitEars.info: http://www.rabbitears.info/contour.php?appid=1283753
As you can see, many Detroit area viewers can receive TVO with the same antennas they currently use for Detroit stations.
For the TVO stations located West of Toronto, they use a 'digital daisy chain' from the main OTA transmitter in Toronto. Any OTA disruption between Toronto heading West causes the HD go away and the system drops back to SD. SD is distributed by satellite (plans are for satellite HD distribution at some point when the money is available) so it's not subject to the same OTA disruption. The other TVO stations Windsor HD is dependent on are Chatham, London, and Kitchener.
They have been experiencing some problems with this system and for the time being they have dropped to SD, and also do not have PSIP. It should take 2-3 weeks to test the proposed fix and if it works, fine, if not it will take longer to correct the problem.
Having seen TVO HD, I can tell you:
1) It's really good 1080i, because they have no subchannels.
2) They offer a wide variety of programming, with many programs not available from other sources in our area. This includes the famous Saturday Night At The Movies series with exclusive films and commentary from industry insiders.
post #11052 of 11539
Originally Posted by DrDon View Post
The HD buildout was completed here about a month or so ago. The changes I spoke of - largely cosmetic - Begin this Thursday. It's stuff the other O&Os are already doing. No biggie.
I happened to flip to WKBD-DT this morning and was stopped by the sheer HD goodness of 'First Forecast Mornings'. I didn't hear much of what they were saying because the video was so good...
post #11053 of 11539
The Tonight Show on NBC WDIV-DT. Dolby Digital is screwed up again; no feed for center & l/r surrounds.
post #11054 of 11539
WMYD-DT channel virtual 20, real UHF 21, is off the air, at least for now. Not sure when it started.
post #11055 of 11539
Before they went off-air, I noticed that their PSIP was messed up and while it was remapping to 20, there was no IPG info.
post #11056 of 11539
Technical issues knock Detroit's WMYD off the air this afternoon
MyNetworkTV WMYD-TV Ch. 20 Detroit has been off the air for at least the past 90 minutes as of 4:30 p.m. The outage does not appear to be affecting the other TV stations (WWJ-TV Ch. 62, WTVS-TV Ch. 56, WUDT-CA Ch. 23) that also broadcast from the same tower. The outage affects both Ch. 20.1 and Ch. 20.2. At least some cable providers are also affected- Comcast is displaying blue 'technical difficulty screens for Ch 20.1, both SD and HD, and Ch. 20.2.
http://www.michiguide.com/archives20...mar-22-20.html
post #11057 of 11539
It's been down since around 2. That's the last time I ran a scan and 20 fell out of my list. Also about the same time as the first report on Facebook.
Strangely, there's no official mention on their website or Facebook page. Unless I missed it.
post #11058 of 11539
Still down as of right now. Must be pretty serious.
post #11059 of 11539
What does the CA stand for in WUDT-CA?
post #11060 of 11539
"Class A." Sort of a low power station that gets RF protection wheras LPs are on their own.
post #11061 of 11539
Not sure when they got back, but WMYD-DT is up and appears to be running like normal again. I hope we hear what happened.
post #11062 of 11539
A poster on another site emailed the station's GM and received this reply:
Thanks for your email.
Our power supply was unstable yesterday and we had to power down our
transmitter to avoid damaging it. This forced us to go off the air while
we fixed the problem. I am happy to say that the problem is fixed and
you can enjoy watching TV20 again.
Thank you for watching our station, we always like to hear from our
viewers.
David Bangura
President/ General Manager
MyTV20 Detroit
Source: http://www.mibuzzboard.com/phpBB3/vi...427306#p427306
post #11063 of 11539
Thx.
post #11064 of 11539
No redundancy? I would think they should have two full exciter/transmitter/power supplies, but it is Granite, too.
post #11065 of 11539
Given the outlay to move from analog to digital, I imagine a lot of smaller stations are rolling the dice until they can work yet another transmitter into the budget.
post #11066 of 11539
post #11067 of 11539
Substantial HD additions and lineup shuffling very simular to what is seen at http://www.mycharterchannels.com/ will be coming to Charter customers in Michigan this summer.
post #11068 of 11539
Good deal. It looks like most Charter areas will have access to over 50 HD channels. This will be helpful for the Lineup topic in the HDTV Programming Forum.
post #11069 of 11539
5:18 and WDIV just went south on BHN. Analog and Digital ....for about three minutes.
IOW, it just came back as I was typing this.
NVM, move along. Nothing to see here. Of course, now I have to re-scan to get WDIV digital back. SIGH
post #11070 of 11539
Has anyone contacted WPXD as of late to find out what the hold up is with going to RF 50?
