AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Detroit, MI - HDTV
Detroit, MI - HDTV - Page 101
post #3001 of 11559
Originally Posted by jwilson56 View Post
Well I have not seen it happen much in the past week. My observation is that when it has been raining it is worse. Have not noticed any planes when it happens and when its acting up its over a longer period (30-40 minutes) of random signal loss. I suspect the wettness is attributing to the overall problem. A tech support person said to try an attenuator on the antenna to reduce the multiplath reception. They are sending a free one out to see if it helps. We shall see...
John
John, I see you are using a DB4 antenna. I'm in Dearborn too (near Telegraph/Carlysle). I have the DirecTV H20 receiver and have a DB2 antenna (mounted outside) connected to it. I get in everything really well, but have had a few issues with Fox 2 (Ch. 2.1) on occasion. The DB4 might be too much antenna. I think its basically a double stacked DB2.
post #3002 of 11559
Originally Posted by brianvann View Post
I have no doubt that obnoxiously large and poorly placed logo isn't going to be moved or shrunk to a reasonable size without lots of people complaining about it.
Count me in as a complainer. That logo is completely obnoxious.
post #3003 of 11559
I went here and sent them a pretty detailed complaint, although I also mentioned that I appreciate the fact that they are offering the Pistons games in HD.
http://www.tv20detroit.com/contactus/default.aspx
post #3004 of 11559
Thanks for the tip, I wrote them a polite complaint as well.
post #3005 of 11559
The cable industry has a divided opinion on passing HD locals in the clear, or not, which leads most knowledgeable observers to believe FCC rules and guidelines are less than clear on the subject. While many cableco's do not pass local HD in the clear, Comcast does. There have also been reports of other Comcast HD channels in the clear, but this is the exception and not the rule.
post #3006 of 11559
Yes, the TV20 logo is really bad.
post #3007 of 11559
Correct me if I'm wrong, but aren't all FCC rules and guidelines public information?
post #3008 of 11559
I believe you are correct, but believe me when I tell you many others at AVS have previously tried to find definitive information from the FCC on this issue, and failed.
What I can tell you for sure, is that the legal departments of these companies simply have different interpretations of the issue. Comcast believes they are required to pass local HD in the clear, other cableco's don't.
post #3009 of 11559
I still can't figure out which regions of the country get the Fox HD college football games. The USC-Oregon St. game is not being telecast on D* channel 95 where the games usually are. It's not like that channel is being used right now.
Makes no sense to me.
post #3010 of 11559
Is there a guide listing which of the Pistons games will be in HD this year?
post #3011 of 11559
http://www.avsforum.com/avs-vb/showt...&&#post8580458
post #3012 of 11559
It's basically every home game, plus (obviously) all games on national TV.
post #3013 of 11559
The Pistons are on now, and the huge TV 20 logo is gone on the HD channel! It looks like our feedback made a difference.
post #3014 of 11559
Anyone know if Comcast is going to be broadcasting the Red Wings games in HD. FSN (and the Comcast guide) says they are broadcasting in HD but I'm not able to find an FSN Detroit HD channel. I checked INHD and that channel is just displaying the INHD logo on a white screen despite what the guide says. Possibly a blacked out HD broadcast of the Wings game?
post #3015 of 11559
Yes, many Red Wing broadcasts on FSN will be in HD. I posted a list of the games a few pages back in this thread.
However, Comcast does not carry FSN Detroit in HD. Only DirecTV and Brighthouse carry FSN HD in the Detroit area.
post #3016 of 11559
My thought exactly, this is great. I'm grateful that they acted on our feedback, and took the appropriate action to keep their viewers (us) happy.
post #3017 of 11559
I wrote them a "thank you" message through the feedback form, just so that they know that someone has noticed and appreciates what they've done.
post #3018 of 11559
Does anyone have any news on Comcast adding FSN HD? The last I saw, someone said an installer said that they were "close".
post #3019 of 11559
They are always "close". If the installer said "No chance for this season" people that really care might bail and go for the dish.
Ask a CSR if they think we are going to get Bin Laden you will probally get the same answer.
post #3020 of 11559
DITTO
post #3021 of 11559
Be patient.
post #3022 of 11559
Has anyone experienced problems using a PVR recording NBC-WDIV (channel 4.1) over the air? I've had problems since mid-September, but it could have been there before, that's just when I've started heavily using my PVR (due to a new baby).
I use a LG-3410A recorder, and when I either record or "timeshift" I the video gets blocky, freezes, or occasionlly the whole unit freezes. I can watch the station real-time no probelm,and the signal strength is just fine. I also record all other channels with no problem, just on channel 4.1 has issues.
Others in the LG-3410 forum have had similar problems with specific stations in other cities. Most speculation suggests PSIP data or bitrates. I have no idea what that means, but does anyone know what WDIV does different, and can they fix/change it?
post #3023 of 11559
is there anyone else here on WOW???
any word on when we are going to update to 1.88??
post #3024 of 11559
I'm assuming you are referring to the SARA version of the Mot Explorer HD?
If my external SATA trial fails, I will be a very unhappy complainer to them. 1.87 has disabled FireWire and that is illegal.
post #3025 of 11559
I have been calling and emailing comcast for a while now, telling them that I would like to see FSN HD added for our area, along with a few other HD channels. I have a feeling if enough people call and do the same thing, we might actually see some additions.
Does anyone know if detroit will also be getting Natl Geo HD and A&E HD when they are launched on some comcast systems in early December? I saw in some other thread that they were going to be added Dec 5th(i think) to the Baltimore system.
post #3026 of 11559
I love how Comcast notes in the cable box guide info box of Pistons games that air on FSN Detroit (channel 39) that the game is in HD. Where? On Direct TV, certainely not on Comcast. I know it's coming soon.
Also why is it that every Saturday the cable guide says that the NBC nightly news is on from 6:30 to 7 on channel four. But when I go to watch it is the wonderful WDIV local news.
And how is it they are able to air a one hour local news cast on the weekends. Are there that many shootings, fires, robberies, and car accidents to cover on a Saturday?
post #3027 of 11559
I didn't notice that because I was watching the Wings game on Fox 2 HD. If the game is produced in HD, why can't Fox 2 broadcast it in HD? It is quite interesting that they indicated the Pistons' game in HD. I wonder if that is a typo or if it's preparing for the addition of FSN HD?
post #3028 of 11559
It's all money related. We charge Fox more money if it goes out of the production truck HD. Doesn't matter that we do nothing different except to downconvert it. Plus it costs more for the HD transmission circuit, and they need to purchase a decoder and have some way to downconvert the HD broadcast for the SD viewers or book a 2nd transmission path for SD. Add all this up and it costs a lot more to broadcast the game in HD. The Pistons are in HD over the air as they are able to recoup these costs in charging higher commercial rates and getting HD sponsorship. As soon as they figure out how to do this with over the air hockey and over the air baseball the games will be in HD.
FSD does a higher volume of shows so they are able to recoup this extra cost. Every broadcaster wants to broadcast everything in HD. Cost is always the reason they do not.
post #3029 of 11559
Have you watched all the the way to 7:00?
I watch OTA, but my experience is that if sports overruns 6:00 PM (when local news should start), that WDIV local and NBC Nightly roughly split the remaining time until 7:00 PM. Thus WDIV may start late and run a few minutes past 6:30, and NBC Nightly is short by the same amount.
post #3030 of 11559
Does anyone else have trouble picking up 20.1 OTA? Antenna web says I should get it (I'm in St. Clair Shores):
* yellow - uhf WMYD-DT 20.1 MNT DETROIT MI 274° 13.9 21
... but I can't get it no matter what I do. Boosted directional antenna, boosted and unboosted quad bowtie, rabbit ears... nothing.
Anyone have some advice? Thanks.
