AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Detroit, MI - HDTV
Detroit, MI - HDTV - Page 325
post #9721 of 11764
Originally Posted by Sea Ray View Post
What's the opinion of you Comcast customers on being forced to use a digital adapter? I have elderly in laws in the area and they hate it when Comcast makes things more complicated for them. In the name of simplicity, about a year ago I got them a nice digital TV with a QAM tuner. This allowed them to get a lot of channels with the simplicity of one remote and no boxes to keep track of. Now they need this digital adapter and with it they'll have its own remote control and the added hassles. For instance sometimes the TV and the box don't turn on/off at the same time and then they get confused. The "all on" button then turns one thing on (either the tv or the digital box) and the other off. It's also another thing they have to store somewhere. In the case of a kitchen tv where space is scarce this is a problem.
I'm quite glad that Time Warner in my area hasn't gone this route. It'd be a pain for me to get 4 boxes for my office TVs as well as my bedroom tv not to mention how it'd screw up taping shows on my 4 yr old DVD recorder.
If they don't need HD, On Demand, an On Screen Guide and just want standard cable then get a DTA. The DTAs always stay on and the remote is not as complex as the regular Comcast remote.
post #9722 of 11764
Yes, I'm ordering them a digital adapter; I assume that's what you mean by a DTA. I haven't seen it yet but I imagine it comes with its own remote and it changes the channels, not the TV. This is problematic for elderly folks because the TV might get switched from ch 3 or 4 or the TV and adapter may get out of sync where one is on and the other is off. They can't understand the concept that changing channels on the TV does no longer gets you new channels. Now the adapter or the digital box does that.
post #9723 of 11764
Put the TV remote away, and delete all of the other channels out of the TV's memory. Problem solved.
The DTA stays on.
post #9724 of 11764
The DTA stays on.
Yeah, that's good advice. I don't know what the adapter remote looks like but hopefully it's better than the Comcast digital box remote. That remote is set up to operate either the TV or the box, so if you want to turn the TV on, you have to hit tv first then power. But then from here on out you want it to operate the digital box, so rather than go through hitting the TV button we generally use the the red All On button.
And oh, have you ever tried to set up closed captioning with that remote? You'd think with the ADA Act and all they'd make it a little easier but No! After reading all I could and hit all kinds of buttons, I had to call find out how to turn on CC and here's how you do it:
You turn off the box but leave the TV on, then you hit menu and you'll get a black and white list on the screen that you can scroll down and set up CC options. You know how complicated it is to tell my in laws how to do all that over the phone? They can't often tell when the TV or box is on.
Now who ever thought that one up?
My Time Warner box has a logical settings button which gives you all kinds of options such as what I use which is setting it to come on whenever you hit MUTE. I saw no such option in this B/W menu with Comcast. But whoever figured up a design where you set the box after it's off? How are elderly folks supposed to figure that one out?
post #9725 of 11764
I went to cancel my comcast limited local basic (17.99/mo) & the guy first tried to sell me full digital tv even though I told him I use DISH for all TV other than local as I travel in my rv a lot & comcast's cable wasn't long enough (lol). Guess he didn't listen. Then he tried to sell me phone service for a higher price than I currently pay vonage. Finally he said comcast would add $15 to my internet cost if I didn't have any comcast tv service (that's almost thievery & I would jump to any other internet provider with good speed, but no others available to me). SO I'ld save $3/ mo dropping the basic & being upcharged. Then he said comcast would lower my monthly bill $10/mo for a year if I kept the basic. So I said OK as $10/mo is better than $3/mo, even though I have added local to DISH for $5/mo and I can get them over my rabbit ears as well. But, I do like having them on the sat when I'm within 200+ miles of home in my rv. So I still have the basic but never plan on using it. In a year I'll try to drop it again. lol.
post #9726 of 11764
Any word on if the HS Football finals will be in HD on FSD?
post #9727 of 11764
That is the plan at this moment.
post #9728 of 11764
Great!
Thx for the update.
post #9729 of 11764
I have one HD TV (Samsung 26B360) hooked directly to a cable feed to get the QAM HD feed and the standard analog Tv channels (2-~87).
This past weekend, I went to CH200 (WXYZ) and it wouldn't change. I did a quick scan and found that ch 200 had been moved to 93-200, WWJ has moved to 93-201. THen there's a bunch of scrambled channesl betweent there and WDIV at 203, and 202 has dissappeared.. Anyone else see that?
post #9730 of 11764
Cable providers change QAM channel locations on a regular basis. Try a rescan and look for channels on all possible locations.
post #9731 of 11764
I noticed this as well, but like Ken said, they change the QAM channel locations frequently.
In case you were wondering:
101 (RTV) - 93.101
130 (THIS) - 94.130
200 (ABC) - 93.200
201 (CBS) - 93.201
202 (FOX) - 78.202
203 (NBC) - 72.203
204 (CW) - 106.204
205 (PBS) - 77.205
206 (MYTV) - 77.206
208 (ION) - 106.208
It can get kinda frustrating on my one TV since it takes almost 10 minutes to do a channel scan of all the channels, but it's not my main to begin with!
post #9732 of 11764
101 (RTV) - 93.101
130 (THIS) - 94.130
200 (ABC) - 93.200
201 (CBS) - 93.201
202 (FOX) - 78.202
203 (NBC) - 72.203
204 (CW) - 106.204
205 (PBS) - 77.205
206 (MYTV) - 77.206
208 (ION) - 106.208
Thx.
post #9733 of 11764
It's no different than what DBS, fiber, and IPTV customers have to do.
It's all about the competition.
post #9734 of 11764
Not having to use a box of some kind was an advantage to using cable. Comcast just gave up that advantage for the reasons I previously stated
post #9735 of 11764
Having to use a box of some kind was an advantage to using cable.
You may think so, but it was a disadvantage for Comcast because analog channels take up a lot more bandwidth than digital ones. The customers who didn't use a box were the least profitable, which makes them more expendable.
post #9736 of 11764
Actually I mis-spoke. I should have written, not having to use a box...
But you did get my gist so I appreciate that.
Your answer makes a lot of sense. It's about maximizing profits for the cable co.
I didn't realize that delivering analog ate up more bandwidth than digital. Now is that true of hi def too? I assumed that hi def took up the most bandwidth
post #9737 of 11764
Depending on the compression, Comcast can fit 2 or 3 HD channels in the place of one analog channel.
post #9738 of 11764
I didn't know that. Thanks for educating me. That's why I lurk around here, to learn something.
post #9739 of 11764
Has technology changed since this article was published?
Digital signals in formats like 720p and 1080p need 19.39Mbps of bandwidth which is five times the bandwidth of the signal of a standard analog TV. MPEG-2 compression is used to conserve bandwidth by HDTV; yet, this is insured. Thus HDTVs use the high quality of their image resoltuion as the selling point.
http://www.buzzle.com/articles/why-h...analog-tv.html
I thought that the HD DVRs needed much more hard drive than the analog ones. Where am I going wrong?
post #9740 of 11764
I still miss being able to tune in the digital channels on my HDTV with out the box. Not including local!
post #9741 of 11764
The article is confusing "analog" with "SD". Analog channels refer to the old NTSC standard, which uses up the entire channel to transmit one station. Digital channels can have many subchannels, each one representing a different station. Typically you will see 2 to 3 HD subchannels or maybe 10 to 15 SD subchannels on each channel.
It is a digital SD channel, not an analog channel, that the DVR records. These SD channels typically have 1/5 of the bandwidth of an HD channel, and that is why an HD DVR needs more hard drive space than an SD (not analog) DVR.
You can see why there is such a push to get rid of the analog channels on cable systems. Every analog channel can be replaced with 10-15 SD channels or 2-3 HD channels. The transition that most of Michigan's Comcast systems went through this year freed up the bandwidth of about 40 analog channels, bringing a bunch of new HD channels with it.
Also, the 19.39Mbps number refers to broadcast (ATSC) television, not cable. On cable, the HD channels are usually a little more compressed than that.
post #9742 of 11764
Update: it looks like all the games (except division 4 which will be tape delayed) will be on FSD-Plus/FSD-Plus HD
http://www.foxsportsdetroit.com/comm...ll_finals4.pdf
post #9743 of 11764
Yay!
Which means some DirecTV subs & at least some Comcast HD subs will be able to view in HD.
post #9744 of 11764
Yay!
The press release mentions Comcast, WOW, U-verse, DirecTV, and Dish.
post #9745 of 11764
Cool.
post #9746 of 11764
Yes, it looks like Tuesday for both.
And Tuesday it is.
Comcast adds Fox Sports Detroit Plus HD on 707 & ESPNU HD on 708.
post #9747 of 11764
I still don't get why I need a digital adapter. Before I was getting all kinds of channels on my digital TV with the QAM tuner. I have a digital TV so I don't need to receive any analog channels. Why can't they just feed me all digital through the wire and let my QAM tuner do the rest? I don't see why I need a digital adapter to receive digital channels to my digital tv.
post #9748 of 11764
It's all about encryption.
post #9749 of 11764
The content owners (ESPN, USA, TNT, etc.) made the cable providers encrypt the channels to prevent illegal use. A digital copy of a program can be reproduced perfectly forever, unless it's encrypted.
post #9750 of 11764
Yep, and that's worked out real well.
