Hi folks,
here the scan frequencies after our final tests. We do not offer
D-ILA with 75 Hz. The frame rate conversion from 60 to 75 Hz is
simply unwatchable. The 75 Hz or 90 Hz are little jerky as well and should only be used when the projector is not scanning to anything else. For CRT use, you definetely go for 100 or 120 Hz.This is as smooth as 50/60 Hz.
Sorry if earlier information stated otherwise, but the hardware would have supported it but is does not make any sense.
Find the actual scan frequency table here:
http://www.vigatec.de/dateien/scanfrequencies.PDF
make it so
spatz
make it so
spatz
