AVS › AVS Forum › Video Components › Video Processors › CI to LT100 Connection
post #1 of 3
How do you connect a Crystal Image Scaler to a NEC LT100? I think the only inputs for the projector are: S-video, VGA, and an optional component adapter, I think. Does the CI do it by component? What is the best way? I am on the verge of buying both products and would like to know how to properly order the Crystal Image.
Jeff
post #2 of 3
if your CI is configured for RGBS, You will need a simple VGA(HD15) to BNC(5) cable. This cable can be had for $15> try bettercables.com or cableusa.com.
Now if it is configured for component(YCbCr) you will need a more problematic cable i.e. 3 BNC to VGA(HD15 with certain pins shorted).
NEC sells such a cable, but you will need BNC to RCA adapters to connect it to the CI.
I think the VGA to 5 BNC cable is a better/cheaper option.
Andrew
[This message has been edited by midi-guy (edited August 07, 2000).]
post #3 of 3
Andrew
Thanks, Andrew.
  Back to Forum: Video Processors
This thread is locked
