Hi,
Just bought a new Extron switcher SW 4 AR HVxi few days ago for around $850. It's a 4 in 1 out RGBHV switcher all in BNC terminal. Very expensive but it suppose a quality product. URL at http://www.extron.com/product/product.asp?id=sw4ar-hvxi
My video processor is a Faroudja VP400A and the projector is the NEC XG85. The setup works fine when direct connect the 400A to the XG85 using 5 BNCs to BNCs connection. But using the Extron in the middle won't work. The projector 'INFO' said the singal is at 62.9Khz (right) and 33hz refesh rate (wrong). I only get a flickering video noise picture! But if I use the Faroudja 15pin monitor output with a 15pin to 5 BNCs cable to the Extron, the singal pass fine and the XG85 see the frequence is at 62.9Khz and 59.9hz refesh rate. Yesterday I borrowed a friend's Faroudja LD200 for a test. If using 5 BNCs to the Extron, the projector can never sync. Again the LD200 15pin output works with the Extron.
What give? I want to use the BNCs terminal of the Faroudja to the switcher! Anyone has any idea? Thanks in advance.
Btw, the 5 BNCs cable from Faroudja to the Extron is okay because I tried using 5 I-joins to direct connect the 5 short BNCs cable to the 5 long BNCs cable from the projector without any problem.
regards,
Li On
regards,
Li On
