Has anyone had problems using the CI v5.2 on a ECP-4100. I have noticed a bending on the image on the raster. Its most pronounced on non-anamorphic 1.85 images.(I assume because in 2.35 mode the bending is in the black bars and not in the image.) I have tried several resolution on the CI and they produce the same effect. I also have a DVDO that I have used though the same cable, but that does not produce these problems.
I am using the component output of a Sony 7700 in the CI. I also tried the S-Video, but the same results. I have tried putting a macrobuster on the green side of the component output, but same problem. Here are a few pictures I took of the inside of the blue lens as well as a screen shot of how it affects the picture. I am only testing the CI thanks to Hi-Rez, but if I cannot resolve the problem, the increase in picture clarity and controls do not outway the use of the DVDO that works well....
http://home.ici.net/~adg/DCIMAGES/DCP00269.JPG
http://home.ici.net/~adg/DCIMAGES/DCP00276.JPG
---Andy Garabedian
[This message has been edited by andyg (edited August 14, 2000).]
---Andy Garabedian
