AVS › AVS Forum › HDTV › HDTV Programming › FOX-HD on D* should be LIVE now..? Yes, finally, as of 12/20/04.
FOX-HD on D* should be LIVE now..? Yes, finally, as of 12/20/04. - Page 10
post #271 of 277
There are no B grade stations listed, only A grade, which are all the LA O&O stations: KNBC, KABC, KCBS KTTV.
DrDon, are you saying I should be alright. I'm pretty sure OC is part of the LA market.
post #272 of 277
Yep. You don't have to worry about signals from other cities like someone in Detroit or Chicago would.
post #273 of 277
Are both channels still up on the engineering card?
post #274 of 277
Assume they are unless bschneider posts otherwise. As you'll notice in the earlier part of this thread, he's really good about keeping us up to date.
post #275 of 277
As I have been saying for the past 3-4 months. PLEEEEASE give me FoxHD by the season premiere of 24! pretty puuhhhhlease.
post #276 of 277
Originally posted by Ken H
Ho Ho Ho, is that Santa I hear coming down the D* chimney?
Yes indeed.
post #277 of 277
  Back to Forum: HDTV Programming
This thread is locked
