This will be my personal preliminary imprsssion with the I-O DATA AVEL LINKPLAYER2(AVLP2).As a owner of Momitsu V880,V880N had been ranked first in my waiting list of DVD player.Actually, I lived in Taiwan and the company of Momitsu is also in Taiwan. So, it would by very convinent to buy V880N and get service.Personally, I had been very satisfied with V880's picture quality even with so many bugs which most had been fixed by firmware upgrade.
But as a network-based dvd player,the AVLP2 beat the V880N with its new Sigma chip with USB2.0,high speed wireless lan and even lower price.
I just received it for 3 days and I did not have much time to test it(I worked W1-W6 8pm to 9:30pm). So this would be a very preliminary report. I am not good in English. So the response to questions may be incomplete or delayed.
The first part of my expreience will be the player's basic function and building quality. Later,maybe I'll tried to comment on its picture quality comparing to V880.
Just like most Japanes products, the package,the manual and the remote all seemed built with a better quality than V880 even the player was made in China. The sense and response of the REMOTE is better than V880's to me. Both V880 and AVLP2 use EPO's dvd-rom with different models.
The software was called "AVEL LINK SERVER". I had installed it in 2 PCs one was WIN98SE and the other WINXP SP1. Even, it was Japanese,the installation of the software was very smooth without any problem in my Chinese system. I did not expreience any Java problem. The "AVEL LINK SERVER" did not include internet access or any itune-like function as in V880.
The main interface in AVLP2 included:
main setup
lan setup
wireless setup
time
upgrade
dvd player setup
It is very easy to setup lan or wireless just like ususal PC.
It also had a video toggle button like V880.
It supported :
composite and S
D4 480I, D4 480P, D4 720P,D4 1080I( D4 means component)
DVI 480P,720P,1080I,640X480,800X600,1024X768,and 842x480 for plasma
TV
The response to button of video toggle seemed more rapid than V880. And I did not expreience any problem with video toggle which I had expreienced in my V880 initally.
Also, to now I had not expreience any abnormal freeze needing unplug the power cable as happening often in my inital V880
Yes,with the player's DVD-ROM,you can only get component output. The DVI output can only be achived via networked hard disc either in your PC or portable USB2.0 hard disc. In the FAQ of AVLP2 in I-O DATA webpage,they say because it's not HDCP compliant ,so the DVD-VIDEO(or the dvd-rom in the player) can not output from DVI. Anyway, when you rip the dvd to hard disc, you still can get DVI output.
Yes,it can just play VOB file not IFO file.When you push the next chaper button, it skip to next VOB.But if you want to keep the chapter serach fucntion,you can still keep it by using like "SAMRTRIPPER" which could rip your DVD to hard disc by chaper, then you can get a VIDEO-TS file with ex.
20 VOBS if your DVD have 20 chapter.Of course,no menu.
To be continued.
main setup
lan setup
wireless setup
time
upgrade
dvd player setup
It supported :
composite and S
TV
To be continued.
