Not sure what kind of antenna you have, but a good directional antenna might be necessary. If you get 5 and 25 pretty well now, this is a good sign that you should get CBS, NBC, and PBS from Alexandria alright if you fine-tuned the position of the box. Try manually tuning 35-1 and 26-1 and see if the box will find them (while playing with the antenna's positioning, if you're interested in that).
That you get Fox on 14 means you might also receive the networks (other than NBC) from Monroe as well with the proper antenna. Note that ABC and PBS from Monroe are both at very low power currently, and that those in addition to CBS will be on VHF when all is said and done (CBS is digital on 7 right now). The Fox digital is on UHF and at 1000 kW so you should be alright if you can see their analog.
CW is currently analog-only, so don't expect anything digitally there til the transition.
I put Boyce LA into TV Fool, not knowing exactly where you are, and it looks like KALB (NBC and CBS), KLPA (PBS), and KARD (Fox) should be pretty easy catches, with KLAX (ABC) and KNOE (CBS) being more difficult but doable with the proper antenna. Would you mind posting a TV Fool plot for your new location? Even if you decide you don't need the help, I'd be curious to see what it predicts your reception to be like versus what you actually see.
- Trip
