Originally Posted by blastoff
HDFinder,
I don't understand why you are not getting the Redding TV stations now? I don't know how your antenna is aimed or what type you are using. KRCR is still broadcasting the digital signal on UHF34.
What type of receiver are you using?
Here is the channel assignment (first is current, Second is digital temporary, third is Feb. 2009 channel assignment):
KRCR DT ABC 07 34 07
KIXE DT PBS 09 18 09
KHSL DT CBS 12 43 43
KNVN DT NBC 24 36 24
KCVU DT FOX 30 20 20
HDFinder,
I get all of the stations now with no problem at all. Well, recently I have been losing KIXE but I don't know why. Maybe since they changed they tweaked the power or something. But my strength is low.
- 7.1 / 7.2 - 87%
- 9.1 / 9.2 / 9.3 are holding at 41% (I should go adjust or something just to check)
- 12.1 / 12.2 - 95%
- 24.1 / 24.2 - 98%
- 30.1 / 30.2 - 92%
Now when I flip over to 18.1 I have 41% and no signal is displayed.
I am using this antenna mounted to my Sat dish pretty much facing South/South East. It is not very finiky, so small adjustments don't change my strength much.
http://www.radioshack.com/product/in...ductId=2253765
I'm connected directly to my television (Sony KDF-E42A10). I will be connecting my antenna to my AM-21 this week when it arrives (hopefully). I do have a few PBS recordings, so this could present a problem as I am not picking up the signal. I am forcing the tuner to scan digital channels, maybe it will then pick up 18/34.
But as you can tell, I have no problem at all receiving either UHF/VHF.
So here is the result of my latest scan...
9.4 - 70%
9.5 (create), formerly 9.3 - 70%
9.8 no signal with 70% strength
9.9 no signal with 70% strength
There were no signals found on 18 or 34 even though they broadcast with high percentage strength.
