Audio:
The dvd player has both Optical and 5.1 Analog out. I used both outputs and connected them to my receiver. If your receiver does not have 5.1 Analog then your stuck with Optical or Coaxial. In addition, you will not be able to enjoy SA-CD. I then went to the DVD player menu and selected DIGITAL & 5.1 CH Output. This will allow you to use both outputs and you would use your receiver to select which output you want to use.
Black Level:
The DVD player has a black level feature which lowers the standard black level. You should use this when the picture becomes too white. In addition, you can choose other picture modes (Standard, DYNAMIC1, DYNAMIC2, CINEMA1, CINEMA2 & memory) that effects the black level and the overall picture. There's also a sharpened option that enhances the outlines of images to produce a sharper picture.
This player has a lot of features and in my opinion a great DVD player. I picked this player up for $259 with shipping from
www.datavis.com.
