Originally Posted by lgodave
Now a few questions to narrow your issue.
Before the "rescan" after the transition were all your OTA HD channels available? (Except maybe CW 18 or others that might have moved/added channels after the official transition?) If the answer is YES... then you might be able to manually add those channels back if the TV has an "ADD Channel" feature (doesn't require a complete rescan).
The only other issue is if you "rescanned" using a Cable or Antenna setting. If you didn't use the correct setting the available channels would be wrong.
Keep us posted.
Keep us posted.
Thank you for the quick reply.
All of the channels were available, but i constantly got a weak signal with mptv, cbs, and abc. When i go through the missing channels, nothing is listed as say 58-1 or 12-1. Its like high numbers such as 107, 117, and 120. I have no idea which one represents cbs, abc, and mptv.
I just reset the tv to factory settings and did a scan choosing auto. It still has not picked up cbs, abc, or mptv. Its very frustrating and I want the cbs hd for this weekend to see a football game.
