AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Milwaukee, WI - HDTV
Milwaukee, WI - HDTV - Page 4
post #91 of 403
Originally Posted by aaronzott View Post
Are you having any problems with Fox? It seems to be skipping or dropping all the time today during the College game, and there are many hiccups during football. It used to be almost perfect when I first started watching.
Anyway, here are the channels I've found:
NBC HD: 103.2
FOX HD: 103.3
TMJ+: 103.4
CBS HD: 109.1
ABC HD: 109.2
MPTV HD: 116.5
There are also some other MPTV channels in the 116 area.
Sometimes they move around though. ABC and CBS have flip flopped a couple times since November.
Thanks for the help! I am experiencing problems with Fox HD as well, today seemed worse than yesterday.
post #92 of 403
I recently had dish network install the HD box in my house. My tv is a 42" Sharp Aquos 1080 and I'm having issues getting the local channels in HD. What do I have to do get these in HD. I've been reading about having antennas but I thought both dishes I have on my roof would take care of this. I'm a rookie when it comes to this so please talk baby talk when explaining. All I want is my HD channels and to see football in HD.
Gary
post #93 of 403
Plus I'm in milwaukee off 110th & Hampton
post #94 of 403
Dish (E*) doesn't carry the local nets in HD, you need to have an antenna & pick the channels up OTA.
post #95 of 403
Or Time Warner cable.
post #96 of 403
Alright guys I hooked up my antenna and low and behold I got em. Now one more stupid question, the local HD channels don't look very hot. How do I know when they are in true high def. My signals are at 90. Thanks alot guys
post #97 of 403
Your set should be able to indicate what type of broadcast you're receiving, via perhaps an "info" button or similar. What type of antenna do you have? (And what type of tv?)
FYI- I have a "roof top" antenna (um, I think about 15 feet long), but it's actually installed in my attic. I used antennaweb.org to help align it properly, but still wasn't getting a great signal. Went back to RadioShack and added an antenna signal booster-- boy, that did the trick, and I get *ALL* the local Milwaukee Digital channels clear as can be, and my HD programming looks subperb.
Finally, thanks MUCH to whomever pointed out a few pages back that 10-1 and 10-2 are actually "10" and "36" (analog) delayed by 3 hours. I never caught that, and couldn't understand why "10" wasn't also "10-1". (why the delay? Seems odd......)
post #98 of 403
I am hoping you guys can give me some suggestions. I have Time Warner Cable in Milwaukee, WI. In early december my wife and I purchased a 60" XBR2 and upgraded to the HD DVR SA8500(passport). Since we did that, when watching HD channels we get random pixelation and/or split second audio cut outs. It doesn't happen all the time. During the superbowl it was terrible. Also during American Idol it can get bad. It seems to be random and intermittant.
I have contacted TWC several times. I had a tech come out and look over all my equipment. The levels are all within the right range and I am getting good signals according to the service menu. He could not figure out what was causing it. He gave me some lines about how it was a "plant problem" and that he would page them and have it fixed within a day. Nothing ever happened. I called back again and another tech is coming out tommorrow. The last tech that came out was giving me all kinds of crap about how it was because I was using HDMI and Optical TOSLINK cables, etc etc, and that I should be using rca connections, etc. I told them he is mistaken.
Is this just what I should expect with TWC HD cable? Can I expect this ever to be fixed or is it just the norm?
I am using HDMI for video to my tv and optical to my sony reciever for sound.
Please help.
post #99 of 403
So i just moved to Milwaukee from NY, and had Directv move my stuff from NY to Milwaukee, and for the first time ive ordered HDTV. Im a little saddend to find DTV doesnt carry all of the locals for this market.
post #100 of 403
Welcome to Wisconsin, What is your zip code ? Most of the Milwaukee TV station is on the north side. I would go to www.antennaweb.org and enter your address and uncheck the 2 boxes below the zip so you don't get the junk mails and then go to options and put 100 ft in the height box and it will show you what you should get and which way the TV antenna is at and how far away you are. All the Milwaukee station for Digital is in the UHF expect for PBS 10 ( DT ch 8 VHF-high ).
Better yet go to this HDTV Reception Hardware and post your question there http://www.avsforum.com/avs-vb/forumdisplay.php?f=25 You would get quicker responce there. Just prodive your zip and give little detial like living in house ? or if an apartment what floor you on and north, east south or west side of the building and what model dish reciver do have now.
post #101 of 403
aaronzott and Nick3092:
Reading some of the old posts about how one of you can pick up the HD channels via the QAM tuner and the other can't, I had a curious question come to mind. Do you both have Roadrunner as well as your TWC cable? I think the Roadrunner connection may have something to do with that as well, because last year I dropped my cable but kept my Roadrunner. Turns out I could still get about 5 channels on my TV (just talking analog channels here). I don't have a QAM tuner that I could have checked on, but I am curious if maybe I could have picked up some of the locals that way. I know the cable company must have many different kinds of filters they can use to block certain frequencies on the line. In my case they couldn't completely cap the line because they had to let the Roadrunner signal though. I'm fairly sure either the upload channel or the download channel overlaps with the analog channel 4 signal, because anytime I'm on the computer, I can see whenever I request a new webpage to load because I get interference on the TV (just channel 4 though). I seems to me the other analog channels I was picking up when I wasn't subscribed to cable were in the 60-70 range...so that must be the other area where Roadrunner uses to upload/download info. Does anyone have any idea what frequencies are used for Roadrunner.
The reason I bring this up is because I need to cut back on my monthly budget, so I'll be dropping my cable in a few months (when a roommate moves out). I have a few OTA boxes I can use, but I only have indoor antennas...therefore I get some signal breakups when watching shows. I hope to keep my Roadrunner, and will be in the market for a 37" LCD HDTV soon, so I'm trying to determine if I need to make sure I have a QAM tuner in the TV to possibly pick up the QAM HD channels off TWC. It would be very cool if some of the HD channels are in the frequencies that will still be coming to my house via the Roadrunner connection!
Mike
post #102 of 403
I have the same question. I'm about to purchase a Sony Bravia HDTV LCD with a built in QAM tuner. Right now I'm subscribed to the analog Standard package (channels 1-99), but will downgrade to the basic package. But I also want to know that if I drop cable TV completely but keep my roadrunner service, if I will still be able to pick up local HD channels through the coax connection (just splitting the connection from the wall: one going to computer, one going to TV)? If so, I would be happy to cut my costs to just subscribe to roadrunner but having HDTV through the same outlet and not having to pay for basic cable.
By the way, where in Waukesha are you at brewtownska? I moved up to Waukesha from St. Louis at the beginning of February. I'm in an apartment complex off Northview Road.
Mike
post #103 of 403
I subscribe to only Roadrunner (no TV package) and I get all the unencrypted HD channels just fine. Both ATSC and Roadrunner use QAM modulation. It would be hard to filter just one but not the other. Likewise I'll bet non-Roadrunner-subscribers still get the Roadrunner signal, they just can't tap into it.
post #104 of 403
Please help.
Actually, I think the HDMI ports on the HD DVR SA8500 are sketchy. I alos have a Sony SXRD, but it's the non XBR 50". I tried my HDMI port, and it did lots of odd things, like the picture randomly blanking out for a few seconds. I've been using the component connections and everything is fine. I also use my HDMI on my DVD player with no problems, so I think the cable box's HDMI port is just messed up.
post #105 of 403
Mike
I don't believe my issue was with TW, I believe it was with one of my TV's. I had a lengthy e-mail exchange with a TW tech who finally admitted the channels are there via clear QAM, but TW provides no support for them, because they don't "broadcast" them. And apparently when they say "broadcast", they mean officially advertise the fact they are there. Anyway, since I had one TV that picked them up, and one that didn't, after a lengthy conversation with the manufacturer, they did acknowledge that I had a very old version of the set (even though I had just bought it 3 weeks earlier) and agreed to exchange it for a newer version. I'm still waiting for them to ship it back to me to test it out.
Also, roadrunner uses a very low frequency for upstream (my modem reports 33008000 Hz for upstream) and a higher one for downstream (my modem is reporting 711000000 Hz Locked). For those of you that don't know, you can point your browser to http://192.168.100.1 and most modems will give you some status/diagnostic screens. The Motorola surfboards give you some nice readings on signal to noise and down/upstream powerlevels. I basically used mine to test my signal strength coming in from the cable company, and at several jacks around the house to make sure my cabling was all good.
post #106 of 403
Do you also receive any analog channels? If so, could you tell me which range? Thanks again.
post #107 of 403
Most are blocked but I do get a few analogs - TBS (channel 3), Discovery Health (channel 60-something), and maybe a couple others. But they're all a little snowy.
post #108 of 403
I can't seem to find a way to get the CW in Milwaukee via OTA or TWC. Is there no broadcasting of this channel in the Milwaukee area? I would have expected it to be one of the major networks.
post #109 of 403
CW in Milwaukee is WVTV- 18 analog ( DT-61).
post #110 of 403
Time Warner has a lot of broadcast issues. I have had them since the day I moved into my own place (years and years ago) and have yet to be impressed. Their SD channels look especially bad. And what's with the analog channel, I though it was called "digital cable?"
I am thinking of switching to the new AT&T dish network. Anyone have good luck with Dish Network in Ozaukee county?
post #111 of 403
Yeah, you can get the QAM channels with just Roadrunner. Every now and then the channel numbers move around which is annoying. Something you won't run into with OTA HD, but it's still (basically) free HD. Unfortunately CW-HD isn't on TWC here yet, though.
post #112 of 403
As of last Thursday (6/28/07) CW18-HD & My24-HD are on TWC on channels 518 & 524.
post #113 of 403
Currently I am a TWC subscriber, and live pretty close to downtown. Thinking about switching to DirecTV since TWC's SD channels are AWFUL! My question is what needs to be done to get the local HD channels- I know from DirecTVs site that ABC, FOX and NBC are all available as part of our local market, but PBS, CW and CBS are not listed in HD. Is this still correct? What are people doing about getting these channels? I want to make sure I am getting AT LEAST what I get with TWC in regards to Local HD, and I want to be able to record using their HD-DVR as well. Thoughts?
post #114 of 403
Are they coming out over QAM as well? That's what I was talking about.
post #115 of 403
Folks on the milwaukeehdtv forum are reporting CW18 on QAM 116 and My24 on QAM 77-3. Not sure what the subchannel is on 116.
post #116 of 403
I went back to D* after 9 months w/ TWC. You are correct that PBS, CW, and CBS are not in HD on D*. However, D*'s HR20 (HD DVR) integrates OTA signals into the guide (as long as you have an OTA antenna set up). I now get all of the local digital signals and I don't have to switch inputs on the tv when switching from D* to OTA - in fact the only way you know you are receiving OTA vs D*'s signal is a change in how the station is displayed in the guide.
No problems recording either D* or OTA.
I don't know how easy it is it received OTA in downtown Milwaukee. If you can pick them up I wouldn't hesitate switching.
HTH
Steve
post #117 of 403
Just bought a new HDTV (with QAM tuner), and using an older Terk antenna (Model AF-1), I can't seem to get 12.1 in, and 6.1 occasionally cuts in and out. Is this a problem with the antenna settings? Should I get a different antenna (indoor only!), or how should I adjust the antenna?
post #118 of 403
Does anyone know what's up with CBS and ABC HD channels? They are no longer showing up for me in the 109 range. The other channels (NBC, Fox, CW, etc) are still working just fine.
post #119 of 403
I'm getting CBS on 85.3 and ABC on 85.1.
post #120 of 403
I currently have TWC here in oak creek wi. I am fed up with their lack of hd channels and their prices are nuts. W/ roadrunner we pay 202/ month. Crazy! I am thinking bout getting directv but i have some questions. Will i be able to see all my local channels in hd? I waatch a lot of cbs and im afraid that i wont be able to receive that. Also how does the hr20 compare to twc's hd dvr box? is there anything i should know before gett8ng directv? Please help me out
thanks p.s. if i get cbs ota, will it drop out or will i not even know the difference. Also, how is the picture quality compared to cable in sd and hd?
