Originally Posted by
arxaw
...How's the SS on KAFT-DT using the 4228?
How far are you as the crow flies from Tulsa? Do you get all their stations?
What preamp are you using?
arxaw, here's a list of the stations I can get reliably, as of today. Don't know if I've got the antenna set just right yet or not, all the signal levels have been consistent for a couple of days now, but I might have to re-adjust after the trees leaf out. I have the antenna a couple of feet lower than I had the 4221, and haven't tried all height/direction combinations. On my H20 a signal level or 40 or greater will give me a consistent, trouble free picture. All the distances came from the FCC database. The Tulsa channels are transmitted from two towers located within a half-mile of each other, about 96 miles from me. There is another independent channel located there also, and some in Tulsa proper and beyond that I can't receive. I also don't get KTUL-DT, the Tulsa ABC affiliate, even though it's closer, because they're transmitting on channel 10 at a piddling 6.9 kW.
...CALL........CHANNEL.RF.....LOCATION...MILES...SS
KAFT-DT(PBS.....13-1....9...FAYETTEVILLE..42.....84
KHOG-DT(ABC.....29-1...15...FAYETTEVILLE..55.....64
KFSM-DT(CBS).....5-1...18...FORT SMITH....41.....98
KHBS-DT(ABC)....40-1...21...POTEAU, OK....26.....70
KFTA-DT(NBC)....24-1...27...FORT SMITH....33.....72
KOET-DT(PBS).....3-1...31...EUFAULA, OK...61.....68
KOKI-DT(FOX)....23-1...22...TULSA, OK.....96.....52
KOED-DT(PBS)....11-1...38...TULSA, OK.....96.....46
KTFO-DT(UPN)....41-1...42...TULSA, OK.....96.....52
KOTV-DT(CBS).....6-1...55...TULSA, OK.....96.....66
KJRH-DT(NBC).....2-1...56...TULSA, OK.....96.....60
As you can see, KAFT-DT comes in well even though it's VHF, 40 miles away and about 75 degrees off the antenna axis. I'm using a CM 7777 preamp with the input set for combined UHF/VHF.
What kind of antenna setup do you have up there? I think you mentioned you receive some Missouri stations?
