Originally Posted by
clmartin22
just found this forum, great info. I have been using my dish network 6000 and 811 receivers along with a channel master 4228 and pre-amp to receive hd programming for about 2 years. WCBI is always great but recently I haven't been able to get WLOV at all. I get a couple of PBS stations and can occasionally get ABC 33 at of Tuscaloosa.
I live outside of Tupelo, any chance I might pick up something from Memphis with some adjustment.
I can't believe WKDH and WTVA aren't broadcasting yet, but this is typical of them.
I get fairly reliable reception from Memphis here in Pontotoc, especially at night. WREG (cbs) is the most reliable, WKNO (pbs) is also very reliable. WPTY(abc) I get about 75% of the time at night,WMC (nbc) is about 50/50. WHBQ(fox) is still under construction. You are probably about 15 miles furthur from the towers than I am, this might make quite a difference since I am probably 20 miles or so from their fringe reception area. Sounds like you've got the right antenna setup though. If the 4228 can't get it, it probably can't be "got". Interesting about Tuscaloosa, I've never thought of them before. I have picked up ABC from Jackson,TN and a PAX channel from Paducah KY before, but not very often. Anyway, get that antenna as high as possible and give Memphis a try! Good luck
Deno
