Review of a tactile transducer in the latest Widescreen magazine started it all...
After several reviews of various "butt shakers" I found on the Internet,
I decided to get one of the Clark Synthesis units and drive it with
the well known AudioSource 5.3 amp (250W at 4 ohms).
Clark Synthesis owners, please advice which model to get.
Besides the relatively high price of the Platinum model,
could it be an overkill?
My intention is to bolt it to a piece of wood and place
it under a sofa cushion. I am leery on vibrating the
whole sofa after my downstairs neighbor banged
on my door during attack of the machines (Matrix).
Q1: Should I get the Gold or the Platinum model?
To see the specs, please use the link below and then
click on the "View Transducer Specifications" link:
http://www.clarksynthesis.com/home-products.php
Q2: What type of wood would work best?
Is plywood sufficient or should I try something more rigid?
Thank you very much in advance for all responses.
Mike
Mike
