Question on Motorola DVR (6412) reset:
Hi-
I have been having some issues with my DVR that make me think that a HDD reset would help (or, at least, not make things any worse). I haven't done this since 2006 and when I tried what I had written down, it failed to work. This is the procedure I have:
Power off
Hit OK/Select quickly
Hit "replay"
Hit MyDVR 3 times.
Hit Live
"Clr" should now be in LED display
Press OK/Select to cause reboot
I get into the Service Menu with the first two lines, but nothing after that gets me to the "Clr" prompt. A quick check of Wikipedia shows that the instructions there are slightly different, with 2 presses of "replay" and 2 presses of "Live" being necessary. I tried that as well, but still no luck.
So, has anyone here successfully reset their 6412 unit recently, and what command sequence did you use?
Thanks in advance,
Alan
