Hello,
I have the DVP-NS975V DVD player.
If you have any questions, please ask them!
Sections:
1. Equipment -- Equipment used in evaluation.
2. FAQ's -- Tidbits and special requests. Information on specific video, audio, compatibility, and hardware details are found here.
3. MISC -- Documentation links and other miscellaneous data.
------------ Equipment -------------------------------------------------------------------
Display: Panasonic TC-22LH1 LCD HDMI 1280x720 @ 1080i & 480p & 480i
Hitachi 32HDT55 Plasma DVI @ 1080i & 720p & 480p
Cable: HDMI-HDMI supplied with DVD-S97S, Monster HDMI->DVI cable
DVDs: DVE, Avia, various movies, animation
------------ F A Q's ------------------------------------------------------------------------
COMPATIBILITY:
DVD-R: Yes
DVD-RW: Yes, VR mode as well
DVD+R: Yes
DVD+RW: Yes
PAL: <tbd>
DVD Compatibility can vary from manufacturer to manufacturer.
OPERATION:
Layer Change: Fast. Maybe .2 secs.
Remember last played position of ejected disc: Yes
HDMI
HDMI->HDMI 1080i,480p
Differences between the modes/resolution noted in red
Deinterlacing Processor: Sony custom
MPEG Decoder: <tbd>
Macroblocking: No
Chroma Upsampling Error (CUE): Possibly, ICP issue definitely
Low IRE gray/pink: No
BTB and crushing: Passes BTB. BUT only with: CINEMA1, CINEMA2, or MANUAL: PICTURE -2, BRIGHTNESS -2. Basically one has to reduce player Picture/Brightness to get BTB to appear.
HDMI->DVI no black/white crushing (Hitachi 32HDT55) @ either 1080i/720p
WTW and crushing: The picture modes will crush white. Set MANUAL to above settings to avoid white crushing.
Color accuracy via 720p/1080i (green depression):
1080i: Depends on display. If the display allows for SD/HD matrix selection then choose SD and it's OK. If the HD matrix is fixed at HD for 720p and 1080i then significant green depression -20% on Avia decoder check. Some green shades noted in near black areas. Might be material dependent. It is noted that if one sets the player's "TINT" to -3 and reduce the "COLOR" to -2, the most apparent visual affects of the HD/SD color conversion issue can be reduced somewhat.
480p: OK
480i via HDMI: Yes
4:3 Pillarboxng: Yes, some loss of detail noted at 6.75mHz.
Non-Anamorphic DVD zoom: No. The picture can be "zoomed" but cannot create a "screen filling" simulation. The zoom quality is pretty lousy, IMHO.
Frequency Response (DVE): Pretty good, some enhancement noted
Avia 4:3 Pillarbox Pixel cropping (pixels removed):
1080i: 7 Top, 3 Bottom, 0 Left, 1 Right
480p: 12 Top, 7 Bottom 0 Left, 1 Right
DVE 16:9 Cropping: 1080i Image is shifted to the top.
Avia Y/C delay:
1080i: looked perfect
480p: Red +0.07
Avia Moving Zone Plate: Fine detail turned to mush
DVE Motion Pattern: Fairly good, motion adaptive
Subtitle synchronization: Good, some combing noted.
COMPONENT
480p, 480i
MPEG Decoder: <tbd>
Macroblocking: No
BTB or crushing: Passes BTB. BUT only with: CINEMA1, CINEMA2, or MANUAL: PICTURE -2, BRIGHTNESS -2. Basically one has to reduce player Picture/Brightness to get BTB to appear.
WTW or crushing: The picture modes will crush white. Set MANUAL to above settings to avoid white crushing.
Color accuracy (green depression): Accurate color, no green depression.
4:3 Pillarboxng:
480p: Yes
480i: No
Frequency Response (DVE): <tbd>
480p: OK but looked a bit enhanced
480i: A bit of rolloff but did not looked enhanced
Avia 4:3 Pillarbox Pixel cropping:
480p (pillarbox): 10 TOP, 9 BOTTOM, 0 LEFT, 1 RIGHT
480i (non-pillarbox): 10 TOP, 9 BOTTOM, 18 LEFT , 20 RIGHT (might be display)
DVE 16:9 Pixel cropping:
480p: Centered well
480i: Image shifted to the right a bit
Avia Y/C delay:
480p: near perfect
480i: -0.07 green
Avia Moving Zone Plate: Turned to much with 480p/i at both rates.
DVE Motion Pattern: OK. 480p motion adaptive
AUDIO:
HDMI passes two channel: Yes
Audio/video delay/sync: Good sync
CONFIGURATION:
Firmware version: <tbd>
HARDWARE:
HDMI cable: No
Composite, L/R audio cable: Yes
Remote: Yes
Batteries: 2 AA
Power cord: Non-detachable
------------ MISC ----------------------------------------------------------------------
RPTV:
<tbd>
REFERENCE:
The owner's manual is located here:
http://www.sonystyle.com/intershopro.../DVPNS975V.pdf
Tray locked:
There have been numerous reports of the tray becoming locked. I have not experienced this problem. However Sony suggests this procedure located here:
http://129.33.22.8/SRVS/CGI-BIN/WEBC...plate=Case.tem
Basically, unplug the player for 30 seconds and try again, otherwise send in for service.
Sony DVP-NS975V HD/SD color conflict
Some TVs do not allow for the selection of the SD color Matrix at 1080i/720p. The Panasonic TC-22LH1 LCD TV allows for selection at 480p only. NTSC (SD) and ATSC (HD) process color in a different way -- not radically different but somewhat different. DVDs are encoded for SD matrix. The DVP-NS975V converts the 480i signal to 1080i. So far, so good. However, in the case of the Sony, the SD color matrix of the DVD is not converted to the HD matrix. In viewing on a display fixed at HD color matix only at 1080i, the differences between matrices with red and blue are slight. With green, however, the difference is significant. Sending an SD color matrix to a display that is expecting an HD color matrix results in a significant reduction of the color green -- the "green depression". The issue is easily seen via Avia or DVE color patterns. If the display cannot change the matrix at 1080i there isn't much to be done. The display could have the color decoders recalibrated to compensate but that might come at the expense of color fidelity with true HD material. The display's color can be boosted to bring up the green but the red and blue become unreal and the color imbalance still exists. Adjusting the "HUE" on the '975V holds some promise. More later.
What does this "green depression" mean to the average viewer with a TV with a fixed HD color matrix at HD resolutions? In viewing the material at 480p (which has no color problem at SD matrix) and switching to the HD matrix, one can see the major difference is in the rendition of facial tones. EVERYONE has a slightly "yellowish" or "jaundiced" look when viewing HD Matrix @ 480p. Many people might not notice but it's there. Switching back to HD Matrix @1080i mirrors what is seen at HD Matrix @ 480p. I can live with the "jaundiced" look as well but, in my view, it's more "in your face" than macroblocking (pun intended).
What can be done? While there are some other subtle problems, the most apparent of the HD/SD conflict issue, in my view, is the rendition of facial tones. By comparing the HD/SD matrix (switchable for me) at 480p has resulted in this suggestion: See manual's page 59. Set "Picture Mode" to "Memory". Set the "COLOR" to -2 and the "HUE" to -3. These settings seem to hide most of the negative aspects of the "jaundice" look and not introduce much of a negative side affect (so far). Of course the DVE "blue filter" will not be correct, but the visual side affects appear to be minor. If this change is done, please refer to page 81 of the manual and have a look at the "Playback Memory" setting. It might be a good idea to set it to "OFF", as any already played discs will reset the picture controls to whatever setting was present when that disc was first loaded. Setting the controls on the player will avoid the issue of affecting the settings for the other inputs, if the display does not memorize the display settings for each input.
To put this in somewhat technical terms:
For HD (ITU-R BT.709-4) Luma (brightness) is defined as:
Y = .2126R +.7152G +.0722B
For SD NTSC (SMPTE170M) and SD-SDI (ITU-R BT.601-5 or SMPTE-259M) the Luma (rightness) is defined as:
Y = .299R +.587G +.114B
Both equations add up to "1".
Look at the difference in the figures of the two systems that add up to Y (1).
If the signals were identical, difference between the red, blue, and green would be "0" for luma and for the individual colors. The following shows what happens when the standards are mismatched:
Mathematically feeding an SD signal to a system expecting an HD signal shows the differences in the systems.
Y = (+.2990R +.5870G +.1140B) ----> SD
Y = (+.2126R +.7152G +.0722B) ----> HD
0 = (+.0864R -.1282G +.0418B) ---> difference between systems
Overall Y (brightness) is unaffected by the conversion but look at the primary colors:
Note that red is somewhat positive, green is quite negative and blue is somewhat positive. If the color standards were the same all of the numbers would be "0". This resulting difference in the equation above is what is seen via the Avia color decoder pattern.
Thank you:
Paul Bigelow
Sections:
COMPATIBILITY:
DVD-R: Yes
DVD+R: Yes
DVD+RW: Yes
PAL: <tbd>
OPERATION:
HDMI
MPEG Decoder: <tbd>
Macroblocking: No
480p: OK
480i via HDMI: Yes
Avia Y/C delay:
480p: Red +0.07
COMPONENT
480p, 480i
MPEG Decoder: <tbd>
Macroblocking: No
4:3 Pillarboxng:
480p: Yes
480i: No
480p: Centered well
Avia Y/C delay:
480p: near perfect
480i: -0.07 green
AUDIO:
CONFIGURATION:
HARDWARE:
HDMI cable: No
Remote: Yes
Batteries: 2 AA
RPTV:
<tbd>
REFERENCE:
Tray locked:
Thank you:
Paul Bigelow
