AVS › AVS Forum › Video Components › DVD Players (Standard Def) › Sony DVP-NS975V FAQ / Brain dump
Sony DVP-NS975V FAQ / Brain dump - Page 3
post #61 of 1495
I have the 975 played via HDMI on a Optoma H77 PJ w/ 92" screen. I notice frequent anomalies which I describe as small areas of high contrast "zebra stripes" on edges of buildings clothing, especially in CG movies like Monsters Incorporated, they are fleeting. I have seen this on all of my "cheap" dvd players and displays. All these years I thought this was normal for "digital" media, however now with my new big screen and resolution it seems bothersome. Is this CUE?
post #62 of 1495
post #63 of 1495
Well, if there is a better choice for equal money I may have to take this puppy back. I'd rather wait until I find one without this problem. Thanks Paul.
post #64 of 1495
Originally posted by GreggPenn
I have to admit I don't understand Paul's comment about an HD or SD color matrix. I assume HD is high def. and SD is standard def. but I was unaware that there are different color matrix's for each. This must be a function on one of his displays and I have to wonder what it really does. (Actually, I recently asked about differences in IRE scales/digital values related to SD/HD source materials and I was told they are the same. So this definitely stumps me).
The DVE disc has a pretty good story on the different color decoder matrix maps for SD 6500K, EBU and HD and why the differences exist.
Rather than IRE values for analog signal outputs of the grayscale, is about the color temp of gray, where it falls in the matrix and how the color temp of gray contributes to the reproduction of the color spectrum.
IMHO, the green push some of use see, is not the SD/HD color matrix issue. It is something else.
post #65 of 1495
Someone wrote in another thread that the Faroudja chip will filter/correct the CUE issue. I own the Infocus 4805 which got the FLI2310. If I feed it with a 480i signal (via component) coming from the Sony, am I correct to assume I'll get rid of the CUE but will get macroblocking issue, thus "transforming" the player in a Panny S97 ?!?!?!?!
post #66 of 1495
Paul,
Do you see the CUE issue via HDMI, Component, or both?
The reason I ask is that I've been trying to observe the issue for myself on the Sony 975 hooked up to my Z2 via component at 480p (my HDMI-DVI cable appears to have been lost by Canada Post - grr). I've fired up both Toy Story's, and have been trying to see it - but so far it all looks good to me. Do you know of a scene or disc which particularly highlights the issue on your setup?
I'm trying to decide if I'm going to keep it, or take it back, and this may be the make or break for it. I've already ruled out most every other upconverting player due to the MB issue, which drove me nuts on the Denon 1910.
post #67 of 1495
With all these problems is it better to get a dvdo hd+ box and just use a normal 480i dvd player?
post #68 of 1495
sckor,
I'll revisit the CUE. It definitely has an ICP issue. I've changed the posting to "possibly".
Paul
post #69 of 1495
I went back and had a look for CUE.
I used the recent, expanded edition Elvis '68 Comeback Special. The "big production" sequences are *loaded* with saturated red against various backgrounds.
Look for:
Opening sequence: Elvis' red scarf against his black leather suit
"Gospel" sequence: Pick whatever -- loads of red against various backgrounds
"Brothel" sequence: This sequence is awash in red. Try looking at the first scene with the opening of the red doors with the red slats. Look at the floors. During the strobing "flapper" scene, the Sony has some odd bright streaks across the screen.
The Panasonic 'S97 has none of these issues.
Paul
post #70 of 1495
Hello,
"Sony DVP-NS975V HD/SD color conflict" (with suggestions) has been added to the MISC section.
Paul
post #71 of 1495
Hey guys
Do you mind if I change directions and talk about the audio performance of this player? I posted my impressions elsewhere, and I would also like to add them here.
My father picked up this player. Well, he is out of town, so now the player is now at my house (he he).
First, I will say that it is very hard to compare SACD players side-by-side. Too many damn cables to swap – along with swapping the disc (Im not buying two copies of an SACD title). And even though I have two complete systems (currently in the same room), you really need to be comparing these players with the same set of speakers. This is one time that I wished I had a Sony ES receiver (they have two sets of multi-channel inputs). In light of all this, I will try to give you my impressions of this player (while I still have it) as a “mini-reviewâ€, based on a (un-scientific) comparison to my Yamaha universal player. Im calling this a “mini†review because I’ve only had this player for a couple of days, and may only have it for a few days more. So dont expect too much.
Supporting equipment:
System 1: Onkyo TX-SR800 receiver
B&W 602S3, B&W 601S3, B&W LCR600, Dayton Titanic III sub (10â€, sealed, 250W)
System 2: Pioneer Elite 54TX receiver
Swan 5.2, Swan C3, HSU STF-3
The players:
Yamaha DVD-S1500 DVD-A / SACD player, $400 MSRP
Adjustable crossover (60, 80, 100, 120), Adjustable slope (12, 18, 24dB/oct)
Build quality: very good (for this price range)
SACD/DVD-A user interface (GUI): very good, Remote: basic (poor)
Extra features: DVD-V video = average, DVD-V audio = poor, multichannel = very good
Sony DVP-NS975 SACD player, $300 MSRP
Fixed crossover (120Hz), Fixed slope (assuming either 6 or 12dB/oct)
SACD user interface (GUI): basic (poor)
Remote: very good. Feels good in the hand. Lots of buttons, but easy to access (navigate).
Extra features: DVD-V video = very good, DVD-V audio = very good, multichannel = poor
Unlike all other players Ive seen/had, this player’s manual does NOT state that distance settings will not work with SACD (I have no way of testing this, though).
The Sony has internal test tones, which I used to make the initial setup (no tones on the Yamaha). Final adjustments (for both the Sony and Yamaha) were made “on the flyâ€, and by “earâ€.
Initial sound review (based mostly on Nora Jones, Diana Krall, and Joe Satriani):
Highs – The Sony’s are open and airy (or that could just be Nora). The highs are smooth, but not as crisp as the Yamaha. The Yamaha is brighter, but it doesn’t seem as clear as the Sony. Im not yet sure which one has the most detail. The Sony’s soundstage is a lot more forward. Overall (so far), I prefer the sound of the Sony.
Mids – The Yamaha has a lot more mid-depth to it. The mids are strong and detailed. The Sony is thinner in the mids. Again, Im not sure if there less detail, but it is definitely not as powerful. I would not pair up the Sony with “bright†speakers, as there may be too much of a high/mid unbalance (mismatch). My speakers can bring out the mids, so there wasnt that much of an imbalance, however in this category, the Yamaha wins.
Lows/Bass – In fairness, I set the Yamaha’s BM to match the Sonys (small fronts @ 120Hz/12dB) and performed a comparison. I then ran another comparison with the Yamaha’s BM set to small @ 80Hz/24dB, then another with the Yamaha at small @ 60Hz/24dB (this is equiv to 120Hz/12dB at 30Hz). Lastly, I tried both players with the fronts set to large (my fronts can handle 50/60Hz) and the sub on (the Yamaha automatically sets the sub to OFF when the fronts are set to large). SACD bass freqs are typically recorded low, and I am used to this as I usually run the sub a little hotter for my discs (especially Nora – which has a lot on the 30 – 60Hz range). Ok, completely catching me off guard was the Sony with TONS of bass energy. When I first read the Sony manual, I wondered why the sub level could set to -15dB (when you usually need +15dB). Now I know. In all four trials (BM cases), the Sony whooped up on the Yamaha. In the final case (fronts set to large, and sub set to on) the lows from both the speakers and the sub were very powerful, and required a quick dial-down at the sub (its behind my sofa) prior to going into the menu for adjustments (the Yamaha automatically pauses the disc when going into the menu, the Sony makes me stop the disc first). Revisiting the manual, I notice that the default SUB level for SACD in 0dB, and the defauld SUB level for DVD-V is -5dB. Based on this bit of information, along with my testing, I would say that the Sony has a built-in low-freq boost (for SACDs), much like some of the higher-end players. No question who wins this category – Sony!
OK, that is it (so far). I was impressed by Sony. It sounded very good with MY system (your system may vary). In the end, I preferred its SACD performance over that of my Yamaha. The Sony’s interface (GUI) could be a little better, though. I believe that there will be a similar ES model (with i-link?) out soon. Im sure it will have a better interface.
post #72 of 1495
Any comments are welcome especially posts as informative as yours! I finally tried out a SACD (The Searchers -- mastered by Steve Hoffman) and listened through some Stax SR-404 Signature electrostatics.
The sound is immensely detailed, the bass as you described, is very powerful -- especially with this somewhat bass-heavy '60s pop recording. I'm impressed and plan to get more.
Paul
post #73 of 1495
I have been listening to the 975V for the last few days and am pleasantly surprised by the sound quality of this machine with SA-CD.
It has drive, rythym, pace and a sense of timing that I have found missing from other affordable SA-CD/Universal/DVD-A players.
post #74 of 1495
Great to hear that "it wasnt just me".
post #75 of 1495
sckor,
I have the Z2 and soon I'm going to purchase the momistu if the sony, panny, or 941 don't beat it out. Let me know on this threat how the hdmi-dvi with the sony on the z2 workout for you.
Guy
post #76 of 1495
Here is some info on this player that I posted in another thread that some may find useful.
I just got my hands on the service manual for this player. Here are some facts.
It uses a Silicon Image HDMI transmitter...
http://www.siimage.com/products/overview_sii9030.asp
The video DAC is an ADV7300...
http://www.analog.com/en/prod/0,2877,ADV7300A,00.html
The audio DAC is an AK4358....
http://www.asahi-kasei.co.jp/akm/en/...58/ak4358.html
The deinterlacer and scaler appear to be Sony proprietary IC's.
post #77 of 1495
Thanks for the details on the 'guts' umr!
post #78 of 1495
I posted those details on Friday.
Doh! I forgot the Audio DAC.:(
post #79 of 1495
guybarth:
Will post about how well it works once my cable arrives. Canada Post lost the one which was sent, and the company I ordered from is out of stock - so it'll probably be next week before I get to try it with HDMI->Z2. :(
However, I watched Shrek 2 on the weekend at 480p over component with only minor calibrations on the Z2, and thought the picture was fantastic. It looked stunning. I don't think any other movie has looked as good on my setup. Not sure if it's the DVD player, or the movie. I noticed none of the CUE type errors, and would have expected Shrek might highlight such an issue given the vibrant colors. I also went looking for it on both Toy Story movies - and haven't seen it yet. Unfortunately I don't have the Elvis DVD Paul was talking about to try it out on my setup.
Still pleased with this player so far.
post #80 of 1495
Can anyone definitively answer whether CUE is present on this player when using the HDMI output? If so, is it present at all resolutions (480i, 480p, 720p, 1080i)?
post #81 of 1495
Rob Kramer wrote
"OK, that is it (so far). I was impressed by Sony. It sounded very good with MY system (your system may vary). In the end, I preferred its SACD performance over that of my Yamaha. The Sony’s interface (GUI) could be a little better, though. I believe that there will be a similar ES model (with i-link?) out soon. Im sure it will have a better interface"
I believe i-link will be a feature that will be dropped in the near future. It's really not suitable for SA-CD. i-link was designed to deliver data in packets, SA-CD is streaming data.
post #82 of 1495
Well, Im not really sure about that. I do know that using i-link (in actual use) is WAY better than any other means. Being able able to use your receiver's (or pre/pro's) pre-setup bass management, speaker level, and room correction EQ far surpasses any "other" solution currently available.
And with 3 i-link players available for under $1000, plus a fourth due any time now, and I believe that a 5th has been anounced, I think that i-link is only going to grow (unless we get sacd via HDMI) and become cheaper (less expensive).
post #83 of 1495
As anyone tried the 975 with any of the Grand Wega IVs. I have the 60XS955 and was curious if anybody had any feedback, especially the "green push" issue.
Lloyd
post #84 of 1495
I am running my 975V on a Sony XBR950, which has only 1 DVI connector. I am also running a Comcast HD box to the same TV. My question is:
Short of buying a DVI switch, should I connect the 975V via DVI/HDMI cable to the TV, letting the 975V upconvert the signal before it gets to the TV (the XBR will then upconvert it again to native res.) and run the Comcast HD box via component cables (and letting the XBR upconvert the Comcast signal), or should I connect the 975V by components (letting the XBR upconvert the signal) and run the Comcast HD box by DVI?
What solution, besides a DVI switch, will provide the optimal results?
post #85 of 1495
from my understanding, the 975 cannot upconvert the signal via component. so if you wanted to upconvert the 975 signal, you will have to connect it via hdmi/dvi and then connect your comcast stb via component.
post #86 of 1495
That is what I understand as well... but what I am trying to figure out is if I should let the XBR950's upconversion engine take care of this for the 975, and have the Comcast 6200 box take advantage of the DVI connection, or whether I should go the opposite route...
post #87 of 1495
I have a 53 inch Panny RPTV with HDMI 1080i input. The S97 I have has macroblocking like a SOB.
Im wanting to know if I should move over to the Sony 975?
Has anyone heard good or bad about the Sony 1080i into a RPTV?
What will the problems be with this setup? Any "green push" or CUE problems? What can I expect with my setup?
I am asking for all your replies as I've got to make the return soon if I do decide...
post #88 of 1495
Yeah, I have Comcast cable as well, and I have mine running to component on my Sony GWIII and the picture is great. So I guess, my suggestion would be to run the STB through component and the 975 through dvi so that you can take advantage of the upscaling to 1080i for the 975.
post #89 of 1495
NismoZ,
Have a look at the first post of the thread. Check out the FAQ section. I have no problem with "green push" (quite the opposite). Trying to decide if I'm seeing an issue with some green tint in near black area. I believe I'm seeing CUE but maybe only a minor case. Other people have reported not seeing it. I have no RPTV to try.
The Sony does not have the issue with macroblocking.
Paul
post #90 of 1495
dhendren13,
The Moto 6200 can output both component and DVI simultaneously. You should let your eyes decide which one looks better on your XBR950. I also have the Cox Moto 6200 with 42WE610. I honestly cannot tell the difference between the two connections. My son who has much better eyesight than mine actually said that the component looked a tad sharper. To me, optimizing the stb connection is more important than the DVD connection as I watched way more HD programs than DVD movies.
  Back to Forum: DVD Players (Standard Def)
This thread is locked
